Heating & Cooling Logo
G
Gail kraft Posted on Oct 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change lightbulb in Prolectric fireplace?
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Oct 30, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5062776
Points
28436
How to Change the Bulbs in an Electric Stove Heating Unit ...
? 3:26
https://www.youtube.com/watch?v=wICIyjUhHfs
Apr 17, 2013 - Uploaded by doityourselfstan
Easily restore them with a pair of light bulbs and a screwdriver.... electric fireplace and it came with a extra bulb but didnt say how to change it.
My Real Flame Electric Fireplace model number 4099 is flashing error code EE
  1. Check the Power. Because electric portable fireplaces run off electricity, the first place to check is in the power supply when the unit is not working. ...
  2. Check the Breaker. ...
  3. Check the Lightbulb. ...
  4. Check Fuses. ...
  5. Clean the Fan. ...
  6. Check Your Model's Manual.
tip
I can not believe I have to jump through these hoops just to change a feaken...
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at [email protected].
Craig Pays
Kenner, La.
2answers
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
How do I change bulb in prolectric fireplace?
Bye hiring a contract or electrican.
How do change a bulb in a classicflame 23ef010gaa
www.electricfireplacesdirect.com/changing-fireplace-light-bulb
Changing a light bulb within an electric fireplace is not hard, but we ... ClassicFlame23" Fixed Glass Spectrafire Infrared Quartz Electric Fireplace Insert - ...
3helpful
Electric fireplace still works, except the flame does not light up anymore? Is there a way to fix this? It is a Chauffe-Air, Model# 6901740100 Cat.No. DFB4047 Mod. Level: MOD A Serial # 26806D6F 093. I...
Find an access door on the back or side or both.
check lightbulbs.
Do not replace with anything but exact bulb.
try taking the bulb to Lowes...I've gotten luck there before with odd bulbs...they have a special drawer for them.
Good luck,
Vinnie
24helpful
3answers
Black soot on glass and black smoke comes out
Remove the burner and clean all holes ,typically at the end of the burner is a cheep sheet metal valve.This valve adjusts the air to gas mixture by rotating it to increase or decrease the combustible air intake.Air must be sucked into the burner as natural gas is injected into it, this makes for a clean flame,The flame should be blue with small yellow tips.If the flame is long and yellow and sooty increase the air intake on the burner valve.
Top Heating & Cooling Experts
Paul Carew
john h
