I contacted Omron and the answer is:
SETTING THE POSITIONING SENSOR
Press and hold the clock button to reset the Positioning
sensor. The Positioning sensor is set "on" as default.
Press the START/STOP button to store the new
setting.
Really This Was Good Information. Thank you For Sharing Wonderful Information. Visit : https://stefeejewels.com
Check out these glasses
https://www.syghtglass.com/pages/crystal-clear-vs-amber-tinted-lens
https://www.syghtglass.com/blogs/gaming-glasses/do-gaming-glasses-really-protect-your-eyesight
https://www.syghtglass.com/collections/prescription-gaming-glasses
https://www.syghtglass.com/products/night-driving-glasses
https://www.syghtglass.com/collections/gaming-glasses-clip-on
THANKS A LOT! FIX IT!!!
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
1Press Menu/Set, 0, 2.
2 Enter the last two digits of the year. Press Menu/Set.
3 Enter two digits for the month. Press Menu/Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day. Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format. Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time whenever the machine is idle in Fax mode.
When the machine is in Sleep mode, the LCD shows Sleep. (See Sleep Time on page 2-8.)
Hopefully that worked correctly and solved your problem!
