I removed the washer & e-Ring from the motor axle but I can't remove the gear. Thanks!!!
May be a burned out collector of the armaturebetween the brush holder and armature ballbearings are maybe poor change the motor , and replace allways 2 brushes if its possible because 1 fieldcoil stator of the motor should have a problem if 1 brush is shorter than the other brush there is a disbalans with 1 long and a short brush , in the early years 50 60 or the more expensive vaccuums like Kirby 600 W motors
it is useful to change brushes buit in 60% of the cases you lost the brushes again in 1 month .
SOURCE: Bissell Powersteamer Proheat 1698 has rusty motor fan
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
476
