For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
Manually turn ON your device (TV, VCR, Cable Box)
Press and "HOLD" CODE SEARCH
Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
Release CODE SEARCH.
Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
Once the device turns off, press and release ENTER.
With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
Find codes for each device and brand below.
Press and "HOLD" CODE SEARCH.
Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
Enter the three digit code from the TV, VCR or Cable Box code lists.
With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code
You can try using these codes: RCA Codes 000,005,007,008,028, 035,037,054,069
RCA Universal Remote Control Programming Codes
Programming Your Universal Remote.The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
y
TV-000
y
VCR-000
y
Cable Box-000
y
AUX is programmed with VCR code 037For brands that require programming, there are two ways to program: Using Code Lists or CodeSearch. Use Code Search if the code lists are not available or if the codes from the lists do notoperate a device.Programming a Device using Code Search:1. Manually turn ON your device (TV, VCR, Cable Box)2. Press and "HOLD" CODE SEARCH3. Press and release the device button you want to set up (TV, VCR, Cable Box) However,if you are using AUX for a device, press and release AUX first and then the devicebutton for the type of device to be programmed (TV, VCR, or Cable). The selecteddevice button will flash once.4. Release CODE SEARCH.5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100times at a rate of once per second).6. Once the device turns off, press and release ENTER.7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6...Hope this helps! Parsos215
This particular TV may have the same code as a Magnavox,Emerson, Funai ,or Zenith. You will have to look in the remote control manual for these codes. This TV was put together by other manufacturers. And in many cases they program these to their origin! Thanks for asking and show a few hands of support!
Yamaha remote has ability to control other devices (TV, DVD, cable box, ...) only by pre-defined set of models. Look up in your manual to the Yamaha where you will find list of manufacturers and models of devices with corresponding codes. If you can find your model there, program it into the remote. If not, you can try some of the other codes, at least program +/- and other simple functions should be quite compatible among brands.
What you need to do is contact the manufacturer of either your remote control otherwise the manufacturer of the Time Warner [aka: cable providers some times also have the info on file for their customers] they store the code information within their internal systems for their customers such as yourself. Otherwise there is normally a paper insert with the remote control or the Time Warner that would list the info for select manufacturers on there. Toshiba has pretty universal IR signals/codes so you should be okay when trying to program in the codes. The manufacturers can also assist you through the steps--believe me it can get frustrating some times!
