Have unplug it and waited 60 sec
Try a hard reset to this set, and check. If it do not help you, the main system control memory IC to this set is faulty, and should be replaced. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
The easiest way is to reset the TV. There are 3 possible resets for this TV. press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in. The reset should take care of any channel lock/ game guard settings
Also Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
Last Volume down on the unit and RH-Split on the remote-- same process
hope this will be helpfull.
Please rates me .
Goodluck...................
or
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip
