To switch your Onkyo PA 7SD amplifier to the auxiliary (AUX) input, follow these steps:
Locate the input selector: Look for the input selector knob or button on the front panel of the amplifier. It is usually labeled with various input options such as "AUX," "CD," "Tuner," etc.
Turn on the amplifier: Ensure that the amplifier is turned on by pressing the power button or flipping the power switch.
Select the AUX input: Rotate the input selector knob or press the corresponding input button to choose the AUX input. The label "AUX" should be indicated on the display or selector knob.
Connect your device: Connect the audio output of your desired device (e.g., smartphone, MP3 player, or external audio source) to the AUX input on the back panel of the amplifier. Use an appropriate audio cable (e.g., RCA or 3.5mm) depending on the available input/output ports.
Adjust the volume: Once you have selected the AUX input, adjust the volume knob on the amplifier to your desired listening level. You should now be able to hear the audio from your connected device through the amplifier.
To remove the aux pins in the amplifier, you will need to disconnect the wires from the aux cable, usually the black or yellow wire is the ground. Then disconnect the right output from the lower left pin of the pot and the negative of the 10 uf electrolytic cap from the lower middle pin of the pot. You can then remove the aux pins from the amplifier.
REFERENCES:
The aux output is usually the connection you use to send the signal to another component such as an amplifier. The amplifier will have an aux input connection.
Using the search feature on the Xfinity remote with my Kirsch system I could find no codes for it. Am going to purchase a better multi remote and will let you know how that goes.
The Aux function is not meant for that purpose.The turntables/Record Players being way too old,now a days the amplifiers do not come with PHONO function that was specially used for playing Records/For turntables.
Check if u have a phono function in your amplifier and if not then buy another amplifier with Phono function coz you need a ground wire [that comes out from the turn table] also to be attached to the amplifier and then only you can get a proper sound.
White = Ground - GD Yellow = Left turn/Brake -LT Green = Right turn Brake -RT Brown = Tail and clearance lights - TM Red or Black (not both) = Battery, aux power - A Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark) White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT Green
= Tail and clearance lights -TM Black = Battery, aux power - A Red = Left turn/Brake - LT
