Question about Motorola DROID Turbo
Received a replacement phone today. How do I transfer SIM card from the damaged phone to new one?
No directions were provided
    Top Expert:
  • Motorola Master
  • 29,156 Answers
Posted on Oct 28, 2015
    Master:
  • 595 Answers
So long as the old sim card was not damaged and that the new phone is either on the same network or is sim free it should just work after you have fitted it to the new phone.
SOURCE:
My SAMSUNG GalaxyS6 isn’t reading the SIMcard. I turn it on it brings up NO SERVICE also INVALID SIM CARD Network lock sim inserted. I don’t understand it was working earlier today.
Do you have, or can you borrow another SIM card to check your phone?
Is your phone locked to a specific
If the phone works with the alternate card, then your SIM may be damaged.
If so you can purchase another SIM card from your provider and they should then be able to transfer your subscriber information to the new SIM card.
If when you connect you get a Network Lock message and a dialog box to enter a key, the phone is most likely locked to a specific carrier and you need the unlock code to proceed.
Do you have an unlock code?
Nov 26, 2017 | Samsung Cell Phones
Can I transfer my phone numbers from my old sim cardto my new sim card or to the phone without having to enter them manualy
Leave old sim card in phone . copy contacts to phone . take old sim out . insert new sim card . copy contacts from phone to new sim card.
Mar 10, 2017 | Cell Phones
My phone was damaged but I have my SIM card and I want to transfer my service to a different phone but it is an AT&T compatible and I had T-Mobile how do I do that
Hi Rusty, When you receive your your new phone just ring your new service provider and ask them to transfer your old number........ CHEERS..
May 04, 2016 | AT&T Cell Phones
Nokia X6 Smartphone SIM CARD NO VALID
This message may be displayed in the following situations:
  • The SIM card is out of alignment. If the phone has recently been dropped, bumped, or opened, the SIM card may need adjusting. Follow the SIM card installation instructions in your user guide.
  • The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. It may also be that your phone is configured so that it cannot be used with a SIM card from a different operator or service provider. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider. Or alternately, contact your local Nokia Care Point for inspection.
Thanks for using Fixya.
Rating the solution is highly appreciated.
Jun 17, 2010 | Nokia X6 16GB Cell Phone
My sellphone get block and now said insetrt sim but the card is there an dstill said the same thing?
First, make sure you have the SIM inserted in the phone correctly. If you do - and the phone still doesn't recognize the SIM card - you may need to replace the SIM card.
This is a common problem with some phones especially when the SIM has been transferred from one phone to another.
Just about the only way to correct it is to replace the SIM card with a new one.
You can purchase one on eBay for a few dollars instead of paying $25 at a retail outlet. Once you receive it, carefully pop it out of the card it is attached to and correctly insert it into your phone.
Put in your battery and turn your phone ON. You should see a 'No Service' message on the screen. If you do, then your phone can now recognize the new SIM card.
Look on the larger card you removed the SIM from and get the SIM number from the card. Then call your service provider and inform them you have replaced a defective SIM card with a new one in your phone. Give them the new SIM card number and in less than 1-minute your phone will be working again.
When it does, the message on the screen will change from 'No Service' to the name of your cellular provider.
Apr 01, 2010 | Pantech C300 Cellular Phone
Phone says insert sim card with sim card already inserted
Mar 29, 2010 | Samsung Beat SGH-T539 Cellular Phone
Cant pass the sim code
If your not really up for the work to go through for this. You can just have T-Mobile give you a new one for your phone. The SIM card transfer you would have done would have saved only your phone book.
If you are into looking to transfer the SIM card. Call your phone maker. In most Cases its Motorola for T-Mobile.
Call them, and tell them that your trying to transfer your SIM into a newer phone. Alas, They should tell you the code to unlock your phone
Hope this helps!
Jan 04, 2009 | Dual Electronics CECT P168 Cellular Phone
How do I register SIM card for new telephone
You simcard service is disconnected so you will need to contact your mobile service provider to have the service on your sim reconnected.
Jun 18, 2008 | Motorola Mobility RAZR V3
Problem with sim card in replacement handset
if the sim is damaged then I'm affraid you are out of luck
Nov 16, 2007 | Sony Ericsson K800i Cellular Phone
Motorola DROID Turbo Logo
78 people viewed this question
Top Motorola Cell Phones Experts
Ekse
Damen Wong
Damen Wong
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
