HEALTH function (Optional)1. This function help carry away the accumulated dirt, bacteria, etc from the evaporator. 2. Turn off the air conditioner, press "CLEAN" button to enter this function and it will show "CL" on the display of indoor unit.
Issue: Memory card Error Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card
You should always format a new CF card or one from which you wish to erase all images and other data.
Please note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
Turn the power on.
Press the <MENU> button and select [ (Set up)] using or .
Select (Format) using or and press the <SET> button.
Select [OK] using or and press the <SET> button.
To cancel formatting instead, select [Cancel] and press the <SET> button.
The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
Press the <MENU> button.
If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
After 15 months of used my Split type A/C model AS18F series suddenly not cooling, I unplugged the unit and clean the Air Filter as well, but still the problem exist.
