Error codes F06 and E01 or E02. How to "master reset"? />
To start, E01 and F06 means that your main central control board (CCU) and the motor control board (MCU) are not communicating with one another properly. The motor control board is located under the tub mounted to the floor of the washer. The CCU is mounted under the top panel of the washer and is the part with about 100 wires going into it. You'll want to remove the top panel and the lower front panel to check the wire connections and make sure they are all secure. If everything looks good, then you just have to somewhat guess which control board you want to replace first, either the MCU or the CCU. The problem is that there is no way to test and determine which part is faulty so it's just a guessing game. That's what makes this one of the worst errors to get. I generally replace the CCU first as that is the part that shakes around a lot more during spin and it's the first place that the power goes from the power cord if there is any fluctuation in power, so it makes since that this part fails more than the mcu.
There is no Master reset. The only thing you can do is unplug for 1 minute then plug back in.
I’m happy to help further over the phone at https://www.6ya.com/expert/george_083af2f0afc0328b
there appears to be a master reset, shown in this youtube video. Just press the water temperature then release, then the soil level then release, then the spin level then release...do this 3 times, wait 5 seconds and press soil level and release, then press start. https://www.youtube.com/watch?v=xpTCLMug...
