Samsung Intensity II U460 Verizon Logo
Rosalie Fuss Posted on Oct 28, 2015
How can I get my samsung intensity 2's back light to turn off?
The back light won't turn off and the phone no longer auto-locks.
kerbe
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Nov 21, 2015
kerbe
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
10790
Points
62
I suggest that you take it to the nearest Verizon store and ask them for technical assistance. It sounds as if there might be a mechanical problem with the phone.
High capacity battery won't work in samsung intensity
I hate to tell you this but this problem generates more complaints with the Samsung Intensity than any other. The on;y solution, that works every time is to charge the battery through your computer's USB port.
tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
tip
How to lock or unlock a Samsung Intensity
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
on Jun 28, 2010 • Cell Phones
1helpful
2answers
Forgot my password for samsung e 390
Hello Dear,
Type the code * 2767 * 3855 # and the phonewill reset to the factory settings. Other interestingcodes for Samsung phones: * # 0228 # BatteryInformation
* # 0673 # Test MP3
* # 0782 # Date and Time
* # 0842 # VibrationTest
* # 1111 # SoftwareVersion FTA
* # 1234 # Softwareversion (short)
* # 1235789 # StateControl of Integrity
Hardware Version * #2222 # FTA
* # 232337 # BluetoothBroadcast Address View
* # 32489 # State ofCiphering
* # 742695 # Softwareversion, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to * # 8999* 8376263 #)
* # 8999 * 8376263 #Software version, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to 742 695* # #) * # 1546792 * #Admin settings (WARNING: not to experiment!)
(* # * 73561 # OperatorCode, where applicable)
(* # 2456987 * # MasterKey) # * # 123580 TestMode main menu (not to experiment!, Equivalent to * # 9998 * 324 #)
* # 9998 * 324 # TestMode main menu (not to experiment!, Equivalent to * # 123580 #)
* # 0002 * 28346 # ItemMenu Handset Volume (sub-menu of the Test Mode Menu)
* # 0011 # NetworkConnection Status
(Same as in Test Mode,which not only returns to the main menu of the Test Mode)
* # 7412359 # Test MenuRadiofrequency
* # 9999 * 0 # NetworkMonitor
(Same as in Test Mode,which not only returns to the main menu of the Test Mode) * # 7465625 # setthe Phone List of Blocks # 7465625 * 27 *code # Remove the "PC Lock"
# 7465625 * 638 * Code# Remove the "Network Lock"
# 7465625 * 685 * Code# Remove the "Multi Lock"
# 7465625 * 746 * Code# Remove the "SIM Lock"
# 7465625 * 77 * code #Removes the "SP Lock"
# 7465625 * 782 * Code# Remove the "Subset Lock"
# 7465625 * 228 #Disable "Activa Lock"
# 7465625 * 2827 #Disable "Auto CP Lock"
# 7465625 * 28638 #Disable "Auto Network Lock"
# 7465625 * 28685 #Disable "Auto Multi Lock"
# 7465625 * 28746 #Disable "Auto SIM Lock"
# 7465625 * 2877 #Disable "Auto SP Lock"
# 7465625 * 28782 #Disable "Auto Subset Lock" Malicious code:
* 2767 * 3855 #Reset Full Phone (back as "just bought") * 7465625 * 27 *code # Set the "PC Lock"
* 7465625 * 638 * Code# Set the "Network Lock"
* 7465625 * 685 * Code# Set the "Multi Lock"
* 7465625 * 746 * Code# Set the "SIM Lock"
* 7465625 * 77 * code #Set the "SP Lock"
* 7465625 * 782 * Code# Set the "Subset Lock"
* 7465625 * 228 #Enable "Activa Lock" to restart the phone
* 7465625 * 2827 #Activate "Auto CP Lock" to restart the phone
* 7465625 * 28638 #Turn on "Auto Network Lock" to restart the phone
* 7465625 * 28685 #Turn on "Auto Multi Lock" to restart the phone
* 7465625 * 28746 #Turn on "Auto SIM Lock" to restart the phone
* 7465625 * 2877 #Activate "Auto SP Lock" to restart the phone
* 7465625 * 28782 #Turn on "Auto Subset Lock" to restart the phone These codes areworth a bit more for all Samsung phones, in particular: Samsung E390,Samsung Ultra Video F500, Samsung F510, Samsung F520, Samsung F700, Samsung SGHi520, Samsung i600, Samsung i620, Samsung L760, Samsung P910, Samsung P920,Samsung P940, Samsung SCHB100, Samsung SGH F600, Samsung SGH i550, Samsung SGHJ750, Samsung SGH I600, SGH i607 Samsung Blackjack, Samsung SGH P930, SamsungSGH Z630, Samsung Ultra Edition 12.1 (U700), Samsung Z100, Samsung Z105u,Samsung Z107V, Samsung Z110, Samsung Z130, Samsung Z140, Samsung Z140V, SamsungZ150, Samsung Z170, Samsung Z220, Samsung Z230, Samsung Z300, Samsung Z310, SamsungZ320, Samsung Z330, Samsung Z350, Samsung Z360, Samsung Z370, Samsung Z400,Samsung Z500, Samsung Z510, Samsung Z520, Samsung Z540, Samsung Z550 , SamsungZ560, Samsung Z600, Samsung Z610, Samsung Z620, Samsung Z650i, Samsung Z700,Samsung Z710, Samsung Z720, Samsung ZV10, Samsung ZV30, Samsung ZV40, SamsungZV50, Samsung ZV60, Samsung ZX10, Samsung ZX20. WARNING: Someof these codes may cause blockage or malfunction of the cell, therefore, it isunderstood that you use them at your own risk.
What is the nam 2 unlock code for the samsung intensity phone?
ya, for the good place to get the unlock code for your Samsung model mobile, just visit this site http://www.wickedunlock.com/samsung-u460-intensity-ii/rs11wp9/ , it provides the step by step instructions and easy methods for unlocking your mobile from the network lock........at the same time to get the unlock code you have to give some information about the mobile to this site that is your IMEI number,network & country lock after that within a short period you can get the code ..........If you unlock your phone using the unlock code then your phone gets permanently unlocked....After that, you can use it with any other network's sim card...........
2helpful
I want to sync music onto my Intensity 2 but it won't connect to my mac. Why is that?
According to this:
http://answers.us.samsung.com/answers/7463/product/SCH-U460/samsung-intensity-ii-sch-u460-questions-answers/questions.htm?page=2
There is absolutely no support or software for mac computers for this phone, nor are they going to release any. This is a windows based phone, so naturally mac is out of the picture on this one.
May 19, 2011 • Cell Phones
45helpful
2answers
Samsung intensity aa icon what does it mean and how to make it go away
there is a AA icon on the samsung intensity II and i looked though the manuel and nothing about it and its not airplane mode either.. wat is it and how do u get it off??
May 17, 2010 • Cell Phones
2helpful
Samsung intensity frozen bootblock
okay this happened to my samsung intensity late at night i freaked and did everything i could think of then i went to my moms samsung intensity took hers and my batery out switched them turned both phones on they were fine switched the bateries back and viola it was all better again. try this if it works great please tell more people. if it doesnt i guess it just fixed my phone sorry. hope it works.
Nov 20, 2009 • Cell Phones
10helpful
2answers
I FORGOT MY SECURITY PASSWORD FOR MY SAMSUNG PROPEL A767, CAN'T GET IN PHONE... PLEASE HELP THANX
Hi Friend,
Kindly note down the below steps,
Unlock Method for SAMSUNG PROPEL A767. No Cables or Software Needed.
1. Turn mobile phone on with unaccepted sim BUT NOT FULLY INSERTED (only push it half way into sim slot).
2. Insert unaccepted sim to phone (push the sim fully into the sim slot).
3. Input *2767*3855# and phone will reboot and will be temporarily unlocked.
4. Input *7465625*638*00000000*00000000#
5. Input #7465625*638*00000000#
6. Input *#7465625# to check the locks....all locks should now be inactive as or similar to below:
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
Check and revert back
Regards,
Ayyasam
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
