When I turn the oven on and then turn the thermostat knob to select the temperature the control panel still shows the time and not the temperature....why is this? It doesn't show any temp or pre set temp! This happened after I was resetting the time when the clocks changed.....maybe I pressed something whilst doing it but I have reset the clock before many times and this has never happened! Hard to cook without a temperature!!!!
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Timer
To Turn Tones Off/On: Press and hold TIMER SET until a tone
sounds. The display will show "TIMER" and "NA9 On" or
"TIMER" and "NA9 OFF." To remove from the display, press
UPPER OFF, LOWER OFF or OFF/CANCEL. Repeat to turn
back on.
