r
rakesh kumar sharma Posted on Oct 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E003 Error code in canon ir2420 photocopier
Displaying Error code E-0000003 on the panel.call service rep
Mim Ranon
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Master 142 Answers
  • Posted on Oct 28, 2015
Mim Ranon
Master
Level 3:
Director Badge:
Answers
142
Questions
0
Helped
39499
Points
1312
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Thinley
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 17, 2017
Thinley
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1449
Points
Hi, my Canon IR 2420 photocopier makes an unusual sound and asks to restart the machine. What can I do?
2helpful
2answers
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
2helpful
How can I reset iR2420 Canon photocopier to factory default setting
Go into the printer user manual that was downloaded when you installed the printer, the info is there.
1helpful
26helpful
3answers
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
2answers
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
System Error: Code E000 Product manual: Turn off for 10 minutes. "if you cannot solve the problem" "call your service representative" I don't have a service rep. Please help. David717
I posted a note with a contact number..this appears to be a service level request
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products inactive_ln.gifcall_small_off.gif800-828-4040us.gifinactive_r.gif
old marine
old marine
ZJ Limited
ZJ Limited
