I can hit the zoom and it will come back but looses it again.
SOURCE: I have loaded Garmin Trip
Open C:\garmin directory then right click on the .exe file "Unlock wizard". Open this file as administrator and behoild it works. Even though you may already have full administrative rights as I did.
SOURCE: 1984 bronco 2-runs 15 min shuts down wont start again for 20 runs
If the fuel filter is dirty it will settle when you turn the truck off. When it runs for a few minutes the debris in the filter will get sucked into the screen and stop the fuel from getting through. If it was a starter or coil, it would not start at all.
SOURCE: in all looses power while driving, turn off the key and back on and starts to run right again.
Check your fuel pump it may be going bad. Check your spark plugs and see if there is oil on one of them if so clean or replace. It could also be a coil or coil wire going bad. You have some testing to do.
SOURCE: 2008 Gaurdian Generac 3cyl diesel shuts off after hitting bump
If you dont find a solution here. Call Generac in Waukesha WI. and get the number for Robert Schwalm Co. He is the best in the Country for Generac I used to be #2 but I havent worked on all the new Generacs. Give me an old RV unit and no one is faster!
SOURCE: 1987 gmc jimmy wont start
yea you have no fuel and sound like a bad harness and the gm's are know for there fuel pump harness's! did you change it when you changed the pump? there is a lose connection somewhere in the fuel delivery system and it's pretty simply! i would check the fuel pump relay on the left hand side of the engine compartment and maybe even put power to the pump at the relay position "b" on the fuel pump relay harness and there should be a one pin connector to put power to also connected to the same position on the relay "b" the wire should be tan and white! good luck
