Motorola DROID RAZR MAXX HD 4G Mobile Phone - Black Verizon Wireless Logo
M
Mary Solberg Posted on Oct 26, 2015
Camera is unable to initialize. How can I fix it?
Unable to initialize camera. Failed to set up the camera device
not sure what you exactly mean when you say failed to set up the camera device. as far as i know the camera on your HTC HD2 is already set up and has its little piece of software that controls it. you may be unable to use your camera in cases when you installed additional software to your phone and altogether the running processes are using up all memory on your phone so when you press the camera button on your touchscreen it cannot start up. another possibility is that you were asking about photo camera problem but you posted in the wrong place. sorry, i'm not blaming it on you bu it may happen.
Computer Unable to detect camera a630
HI there,
May I know if you have encountered any error message appear on the screen of your PC.?
Did you have installed the camera driver completely on your PC?
also;
Try first connecting the camera using a different data cable.
Hope this initial info helps.
Let me know for any further related assistance.
micro
4helpful
Unable to initialized
"Unable to Init" indicates a mechanical error, unless you're able to find a stuck paper or parts of a stuck paper or similar, you'll have to send the unit to service to have it fixed.
1helpful
Camera on HTC dual touch phone worked for a day but now says
very easy,just do a hard reset all of the original programme will b back.
Screen on my sony cyber shot all streaky, unable to take a clear picture.
go to camera menu and perform Initialize camera and check.
if you provide model number of Sony camera it would be easy to help you in better way.
Sep 18, 2008 • Cameras
1helpful
Unable to start camera
perform a master reset.. hold power and push reset button with stylus.
Note: you wil loose all ur data.
2answers
BLUETOOTH! HELP
Go to the start menu, and select Settings. Select Connections from the bottom tabs and find the Bluetooth icon, and click on the bluetooth icon. Select Mode from the bottom tabs and check box that says "turn bluettoth on"
T-mobile dash camera not working
free up more memory (use task manager)
1helpful
2answers
Card not initialized
well i got the a340 and i just got it from my aunt and i got a new memory card and when i go to format it and at the very end theres a window that pops up and says Windows was unable to complete the format and when i turn on the cam it says card not initialized can anyone help me out?
Nov 29, 2007 • Cameras
1helpful
5answers
Card Initialization
When you are viewing your pictures, press the menu button and go into the option menu. then select set-up and go through the menus until you find 'format'. press ok and press left/right to select OK, and press ok. It should then be working.
Top Motorola Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
