BMW CAR STEREO CODES https://www.carstereocode.com/unlock.php?mk=6
SOURCE: e320 reset SRS
Joe here to help,
Without going to a dealer, you need to get a scan tool to reset the srs light. Go to an Autozone store, They will scan it and reset it free of charge.
SOURCE: radio code for 1995 mercedez benz E320
you must got to the dealer for a radio code for you benz. sorry
Usually the Mercedes dealer will give you the code if you are the owner of the vehicle and they might need the VIN# and sometimes the serial# on the radio too.
SOURCE: ac reset for e320
Your Climate control unit may have to be reset. The reset works as follows: With the key in the ignition and in posistion 2 push both the defrost button and the recirc button (at the same time) for five seconds or untill the led lights in those buttons begin to flash. Wait for 30 seconds or untill the led's stop flashing. Switch off the ignition. Check the evaporator temp sensor and pressure sensor for correct functionality.
Courtesy of benzworld.org/forums
