Upgraded my cable service to cox contour and the remote is programmed to control my tv as well as the Contour receiver. When I attempt to control just the receiver it changes the input on the tv. I have tries different remotes with the same results. There is only on setting for the Receiver so I believe there is a conflict between the frequences
Hi Thor!
You have to select "Cable" on the universal remote on the cable to change the channels on the cable box.
And press "TV" on that remote to change or access TV Functions.
Or use only the TV remote only to change Inputs on the TV.
Good Luck,
JP
Thanks for the attempt but not that simple. I understand more than just the basic functions of the universal remote. To be more clear, when I press any button including the "cable" to control the receiver the TV input changes from HDMI 1 input to TV channel 1.
I have tried the following:
Reset the receiver
Tried three brand new remotes
Tried asking Cox tech support, they said they had never in countered such an issue and believed the problem may be the frequencies may be conflicting btween the contour setting for the remote and the ir frequency for the TV.
