Suddenly has stopped sewing and it keeps jamming
SOURCE: I can't sew for more than 1 inch w/o my machine
loopy underneath means upper threading and/or tension wrong
SOURCE: Very inexperienced sewer! How do I thread it?
The way I solved this problem was to take a break! When I resumed I was more patient and found that I wasn't doing the bobbin right. I took my time and got it right this time....hooray!
SOURCE: I was sewing and all of a sudden it started to
Please try removing the bobbin case and then move the wheel.
It is very likely that the bobbin case came out of place and causing the machine to lock up.
Thanks,
Pat
Hi Doreen Richardson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what make model and age please. If the machine is jamming it is usually the timing or threaded incorrectly. Re thread from scratch and check the bobbin is in the correct way - with thread coming back on itself through the tension spring = the small spring slit in the bobbin case.
I have taken it to serviced and the fault looked at thank you for your time
