You water valve is malfunctioning. Remember the dryer is plugged into the wall, which gives it power, so the valve solenoid will open the valve and hence spray the water. Please hire a professional to replace the valve.
SOURCE: Need to know how to reattach the dryer drum
ouch budddie...happy new year ...looking in the dryer are you taking about those there center mass,,,if that attactes the back bearing surport to the drum...,,if that the two parts which i think your talking about ..you have to take the drum all the way out,,because those three screws are shape like a piece of pizza....it will never line up with drum in...
SOURCE: Electric Frigidaire Dryer Model GLER341AS1
there are two tabs that hold the top cover on,they are a couple inches in from each side.push in and lift lid. inside front panel are two screws, remove them then pull front cover out and lift it up of tabs on bottom.once you get the cover off remove belt,the you will be able to see your mess. heating element mounts to back panel.there is a heat sheild that mountws to the back of the drum.then you lift the drum up and put three screws in the drum to the pivot plate on the back panel.
SOURCE: frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
SOURCE: Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
