SOURCE: HP Officejet Pro L7680 All-In-One printer. copies come out black
Probably either the scan lamp or the sensor bar has failed. Do you see the scan lamp glowing under the cover when you try to scan a document? (Lift the edge of the cover slightly and watch the underside of the cover, you should see the reflection from a bright bar of light moving from one end of the original to the other. Do not look directly down into the light if it is on!)
