Why is water going to the bucket instead of getting pumped out the hose? Does this mean the pump has quick working?
Model: GL-DEH-70EIP-6
70 pint/D
For about a year, this unit worked fine with water going out the hose to the floor drain. Suddenly, it began to send water to the bucket, which turns off the motor when full. The dehumidifier is on a level surface. The hose is draining downhill. The hose and the outlet appear to be unobstructed. The unit is not showing an error message. It appears to be working properly, except that the water goes to the wrong place.
a special adaptor is required from the mfg to allow this it bypasses the internal passageway to internal bucket and has a hose connection to what a normal garden style hose can be connected and directed over to a floor drain or pump pit
this method still requires normal maintence and cleaning thought as it can stop up too
I have the same model, same problem on a 2 year old purchase made in 2014. This unit has a pump (and a hose) to drain the condensate.
The pump light started blinking about a week ago, turning cycling power worked for a while, until pumping stopped altogether.
After investigating:
-the hoses are not blocked but there was some algal growth in the tray which I cleaned
-the pump no longer pumps.
-my favorite parts suppliers and other on-line sources have no record of the model/parts etc.
-Called "whirlpool" consumer line in manual
-Whirlpool has been purchased by Garrison and that company has no parts for this discontinued model but did provide a phone number for the pump 800-799-0991. Unfortunately the cost of this small solenoid pump is $74.
I will drain the condensate via gravity to a floor drain as I don't see spending that much for something that broke so quickly and appeared poorly made..
there should be a pump somewhere near the pan, the pickup for the pump must go into the drain pan somewhere if you can find the pump, the nipple the hose attches to is close by please rate
It sounds like the unit should have came with a plug for the hole. You can probably obtain a plug from a home improvement or hardware store or even improvise one yourself. Also, make sure the unit is pitched so that the water actually runs towards the hose.
Unless it can be 100% gravity feed (1 inch drop per foot) you might need this:
Part: WPL8212501 Fits Maytag M7DH45B2A
(Click images to Enlarge)
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window. Stock Status:In Stock
Price:
$107.79 - This part is also known as: 8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
The clog is not in the hose. It's in the hose connection tube inside the unit. To unclog it use an 18" long plastic Zip Tie or something similar that is flexible and will fit into the hole. NO wire coat hangers though. Gingerly work it into the hose connection hose, until you reach a bend in the tubing. This is the tricky part, as you have to get past this bend. Be careful and work it past the bend. Once the Zip Tie bottoms out or you run out of Zip Tie, slowly pull it back out while rotating it. This will dislodge the clog. Once the Tie is almost all the way out, be prepared for water to follow.
One other thing. If the unit stops operating check that the bucket full light is illuminated. If it is remove the bucket and empty the contents and then check the seal between the hose and the drip tray. If there is a small leak then replace the hose gasket and re-tighten the hose.
FYI - Your humidifier does not have a pump. It relies entirely on gravity to drain, when you use the hose connection.
Has anyone figured out how to get a 25-pint Frigidaire dehumidifier (model FDD25S1) to put water out the drain hose for continuous draining instead of into the bucket? It appears to be impossible to connect the hose in a way to avoid water leaking into the bucket.
