A
Anonymous Posted on Oct 23, 2015
How do I make my TV play in Telefunken 5.1 Home Theatre THT-6000HDMIA speakers?
I have a telefunken 5.1 home theatre, (THT-6000HDMIA). I connected it to my tv with HDMI cable, but my tv won't play through the telefunken speakers. There is no aux port, please how do I get it to work?
Grubhead
Level 3:
  • home Master 5,755 Answers
  • Posted on Oct 25, 2015
 Grubhead
home Master
Level 3:
Answers
5755
Questions
Helped
1660152
Points
11417
Does the TV and system have either a coaxil or optical sockets? If it does then I would connect them by one of these. That should trigger the sound. However it might work via the HDMI if you have selected the system to pass digital signals via that connection.
2answers
How can I operate my Telefunken tht-5000hdmi 5.1 home theatre?
Operate your Telefunken home theatre in accordance with the instructions received in response to your request.
Manual for telefunken tdr-100 dvd recording home theatre system
H?,would you please visit the following link..your model is not available but similar models there..additonally you can ask for the customer service on that official web site..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Home Cinema Set Elegance Series 5.1 DVD Player with USB / SD Slot and 5.1 Home Cinema Set
http://www.telefunken.com/index.php?id=70&classifiedcat_id=30&classified_id=196
The audio will not play through the tv from the home theatre unit
because you do not have the dvd player hooked up to the tv, if you want it to play through the tv then you need to have the dvd player connected to the tv.
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Re-set 'Video Setup Page' in Main Setup Menu
hi kevin, just did the same thing, have u figured it out yet?
thanks
tim
Top home Audio Players & Recorders Experts
NOEL
NOEL
 Grubhead
Grubhead
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
