Kenwood KDC-MP228 CD Player Logo
Austin McGowan Posted on Oct 22, 2015
How do I set the clock time - Kenwood KDC-MP228 CD Player
Richard M
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 04, 2015
Richard M
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
2969
Points
20
Here is a link to the manual for this Kenwood deck.
http://manual.kenwood.com/files/B64-3898-00_00_KW.pdf
How do i reset the 24-hour time to 12-hour time on a Brookstone alarm clock
Dozens of models to choose from. All questions on Fixya need 'make model (what it is)' as the first 3 words.
Here are some guesses. The 'control cover' is where you put the back-up battery.
To change the 12/24 hour time format, open the CONTROL COMPARTMENT COVER on the bottom of the clock and adjust the 12/24 TIME FORMAT switch to the desired format .
Self-Setting Clock - Brookstone
Instruction Manual - Brookstone
Brookstone https://manuals.brookstone.com > ... PDF 12/24 HOURS TIME DISPLAY SETTING 1. The "12h" or "24h" will start flashing in LCD2 (Default setting 12h). People also ask
How do you convert a 24-hour clock to a 12-hour clock?"); display: inline-block; height: 24px; width: 24px;"> How do I change my alarm clock to 24-hour clock?"); display: inline-block; height: 24px; width: 24px;"> What is 12.30 pm in 24-hour time?"); display: inline-block; height: 24px; width: 24px;"> Feedback
Setting The 12/24 Time Format; Setting The Daylight Savings ...
ManualsLib https://www.manualslib.com > ... > User manual
Brookstone TIMESMART Self-Setting Clock Radio Manual Online: setting the 12/24 time format, Setting The Daylight Savings Time. The 12 Hour Format Is Set As ...
How to get a sterling and noble chiming clock time set
To set the time on a Sterling and Noble chiming clock, please follow these steps:
Remove the clock from the wall or mantle and place it on a flat surface.
Locate the clock's time adjustment knob. This is usually located on the back of the clock and may be labeled "Time," "Adjust," or "Set."
Turn the knob clockwise or counterclockwise to set the correct time. Be sure to move the hands of the clock in the direction of the correct time.
If your clock has a chime feature, locate the chime adjustment knob. This may also be located on the back of the clock and may be labeled "Chime," "Strike," or "Silent."
Turn the chime adjustment knob to the "Silent" position if you do not want the clock to chime. If you want the clock to chime, turn the knob to the desired chime setting.
Once you have set the time and chime settings, replace the clock on the wall or mantle.
Note: It is important to set the time accurately and synchronize it with an accurate time source, such as an atomic clock, to ensure that the clock keeps accurate time. Additionally, it is recommended to consult the clock's user manual for specific instructions and troubleshooting tips.
1helpful
Nissan x trail set time clock
https://www.nissan.co.il/content/dam/Nissan/israel/services/car-books/Nissan-Xtrail-Car-Book-2016-ENG.pdf
Page 4-5
Clock:
Select the corresponding keys to adjust the settings.
ā€¢ Time Format:
The time setting can be selected from 12 hour
and 24 hour formats.
ā€¢ Date Format:
The day, month and year display can be selected
from five formats.
ā€¢ Clock Mode:
Select the clock mode from Manual, Time Zone
and Auto.
When [Manual] is selected, you can set the clock
mode manually from the [SET CLOCK MANUALLY] screen.
Select [Auto] to automatically maintain the time
using GPS.
ā€¢ Set Clock Manually:
Mode (AM/PM) (where fitted), Hours, Minutes,
Day, Month and Year can be set manually if
[Manual] is selected in the Clock Mode setting.
ā€¢ Daylight Savings Time:
Turns the daylight savings time on or off.
ā€¢ Time Zone:
Select the applicable time zone from the list.
How do I set the time/date etc on my clock? Model 65904 Ecotech solar clock
I don't have specific information about the Model 65904 Ecotech solar clock, but here are general steps you can try to set the time and date on a typical clock:
1. Locate the Time Setting Button:
- Look for a button that is labeled "Time Set" or similar. This button is often located on the back or bottom of the clock.
2. Press and Hold the Time Setting Button:
- Press and hold the "Time Set" button until the numbers on the clock display start flashing or blinking. This indicates that you are now in the time-setting mode.
3. Adjust the Time:
- Once the numbers are blinking, use the "+" or "-" buttons to adjust the hours and minutes. Some clocks may have separate buttons for hours and minutes, while others may have a single button that cycles through hours and minutes.
4. Set the Date (if applicable):
- If your clock displays the date, you may need to follow a similar process to set the date. Look for a "Date Set" button and adjust the date using the same method as adjusting the time.
5. Confirm the Settings:
- After setting the time and date, press the "Time Set" or a similar button again to confirm your settings. The blinking numbers should stop, indicating that the clock has accepted the new time and date.
6. Check for Other Settings:
- Some clocks may have additional settings, such as a 12/24-hour format or a daylight saving time (DST) adjustment. If applicable, use the appropriate buttons to configure these settings.
If these general steps don't work for your specific clock model, I recommend trying to locate the user manual or contacting the manufacturer directly for assistance. Manufacturers often provide manuals on their websites, or they may be able to assist you with setting the time and date over the phone.
Jul 20, 2018 • Home
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
ā€¢ Press and hold to adjust the time value quickly.
ā€¢ The digits on the display ? ash in clock setting mode.
ā€¢ The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
2answers
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    I have a c218 and i can't set time
    Hold the 'Clock' button until the display flashes. It will first show the year, next press on 'Clock' with show the month, then the day, then the time. Use + and - to set your time and press 'Clock' again.
    Don't expect this clock to set the time by itself. It is not an atomic clock.
    How do I set the time on my Pioneer RT500?
    Hi!
    Please follow the instructions given below... =)
    Setting the clock
    The clock is set to the correct time automatically, but it
    can also be set manually. The clock can be set for
    daylight saving time and time zone.
    Preparation:
    • Turn ON the TV and set it to the video input mode.
    • Select “CLOCK” from “SYSTEM SETUP”. For the
    procedure, see steps 1 to 3 in “Using the SETUP
    MENU”
    1 Press SETUP while the DVD and video tape is
    stopped.
    The SETUP MENU screen will appear.
    TIMER REC SET
    SYSTEM SETUP
    AV SETUP
    REC SETUP
    CH SETUP
    OTHER
    SETUP MENU
    ENTER/
    SELECT ENTER RETURN BACK SETUP END
    SELECT
    2 Press  or  to select the desired menu and
    press ENTER.
    The submenu screen of the selected menu will appear.
    TIMER REC SET
    SYSTEM SETUP
    AV SETUP
    REC SETUP
    CH SETUP
    OTHER
    LANGUAGE
    PARENTAL
    CLOCK
    DISC SETUP
    OTHER
    SETUP MENU
    3 Press  or  to select the desired submenu and
    press ENTER.
    The screen for the selected submenu will appear.
    CLOCK (manually)
    You can manually set the date, year and present time
    with the remote control.
    Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
    1 Select “CLOCK” and press ENTER.
    01/01/04 12:00AM
    2 Select the desired items using  or  (month,
    date, year, hour, minute and AM/PM) then press
    ENTER.
    3 Press  or  to set the value of the selected
    item.
    • For the minutes, press  or  once to set the time
    minute by minute, or hold down either of buttons
    for several seconds to set the time in 10-minute
    intervals.
    10/30/04 10:200AM
    4 Repeat steps 2 and 3 to set the date, year and
    present time, and press ENTER. The SETUP MENU
    will close.
    This completes clock time setting.
    AUTO CLOCK
    You can automatically set the clock by turning “ON” the
    AUTO CLOCK function.
    When you want to set the auto clock function to “OFF”,
    select “AUTO CLOCK”, press ENTER and select “OFF”
    from the list.
    Auto clock setting
    Preparation:
    You must connect the antenna or cable before connecting
    the AC cord to the power source.
    Wait 30 minutes with the power turned off, after the
    antenna or cable is connected, for the auto clock
    feature to activate.
    After the clock is set automatically, you may have to set
    the time zone and daylight saving time. (See page 26.)
    Press STANDBY/ON to turn on the DVD/VCR after the
    auto clock operation completed.
    • When shipped from the factory, the “AUTO CLOCK”
    option is set to “ON” position.
    • If you turn the DVD/VCR on during auto clock
    setting, the clock is not set.
    • After a power failure or disconnection of the power
    plug, the clock setting will be lost. In this case, wait
    30 minutes before turning the DVD/VCR on.
    • With cable box connection, if the auto clock setting
    is unsuccessful, select the PBS channel carrying
    the XDS information, then turn the DVD/VCR off.
    After 30 minutes, turn the DVD/VCR on.
    • If the clock is not set automatically, set the clock
    manually.
    STANDARD TIME (Time zone)
    In the rare event that you live within the broadcast range
    of two stations in two different time zones, the DVD/VCR
    may recognize the wrong station for the auto clock set.
    To correct the situation:
    Select “STANDARD TIME” and select the time zone from
    the list below.
    Selectable time zones and correction times
    ATLANTIC: GMT – 4 hours
    (GMT: Greenwich Mean Time)
    EASTERN: GMT – 5 hours
    CENTRAL: GMT – 6 hours
    MOUNTAIN: GMT – 7 hours
    PACIFIC: GMT – 8 hours
    ALASKA: GMT – 9 hours
    HAWAII: GMT – 10 hours
    AUTOMATIC: AUTO SET
    Note
    • When shipped from the factory, the “TIME ZONE” is
    set to “AUTOMATIC”.
    • After making the auto clock setting, in some cases
    the clock may display another time zone. You can
    correct the clock by selecting your time zone
    setting above.
    • When the clock is not set or you set the clock
    manually, the time zone setting is not available.
    DAYLIGHT SAVING TIME
    You can set the clock to daylight saving time automatically
    or manually.
    To select daylight saving time, select “DAYLIGHT
    SAVING TIME” and select “ON”, while to cancel the
    daylight saving time, select “OFF”.
    ON: For manual setting (forward 1 hour)
    OFF: For manual setting (back 1 hour)
    AUTOMATIC: For automatic setting (read XDS in
    the signal)
    Note
    • When you want to set daylight saving time, on the
    first Sunday in April you set it to “ON”, and on the
    last Sunday in October you set it to “OFF”.
    • When shipped from the factory, the “DAYLIGHT
    SAVING TIME” option is set to “AUTOMATIC”.
    • When the clock is not set, the daylight saving time
    • When there is no daylight saving time in your area,
    always select “OFF”.
    1helpful
    Setting the time
    On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory.
    Now, to those switches: The first (from the left) is DST = Daylight Savings Time - right now you'de set this to "ON."
    The second switch is Time Zone: PST, MST, CST, EST (Pacific, Mountain, Central, Eastern). Set the switch to the time zone you are in.
    The third is just the brightness.
    Now, to set the time itself:
    1 - Turn the clock face back up to where you can see it.
    2 - LOOK AT THE CLOCK - LOL! This is an atomically set clock - you shouldn't need to set the time. The atomic clock bounces off of satellites all around the world. There is literally little to no "dead zones" for the clock, so you should never have to set your clock - just set it up like I state at the beginning.
    Good Luck!
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    ZJ Limited
    ZJ Limited
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
