Microsoft Office Publisher 2007 for PC Logo
R
Rob Napier Posted on Oct 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to start page numbering at 3rd sheet
I have a booklet document in Publisher which inludes the cover. I therefore wish the page numbering to start at number 1 on the third page. I have created different Master Pages for pages 1,2,31,32, but the pages still start from the front cover.
Terry Hair
Level 3:
  • Microsoft Master 4,134 Answers
  • Posted on Oct 22, 2015
Terry Hair
Microsoft Master
Level 3:
Answers
4134
Questions
Helped
1092058
Points
16804
Try the procedure at this link:
Format page numbers
  • Rob Napier
    Rob Napier Oct 23, 2015
    Terry, Very helpful. Problem solved. Many thanks. Rob
2helpful
I am having trouble with booklet style printing -- under Vista
After a great deal of frustration and trying every permutation possible I succeeded amid an ever rising mountain of paper! . . .and find that I have to totally ignore the "Booklet printing" option . . . but ask it to print landscape; 1 page per sheet; flip on short edge.
Now I need to do the same to crack the sytem for the Cannon Pixma IP4000 inkjet.
Thank you for your consideration.
Printing booklets without reducing contents
Click on the "arrange" tab and then click on Layout Guides, and the margin guides will come up. 1" is trhe default setting, you can set it to whatever you want
I am working with a Ricoh Aficio 3260 machine. I have been sent a 20-page Publisher document laid out in Landscape, each page is set up as 8.5 x 5.5. I want the Ricoh to produce a booklet stapled...
Well, I don't have a document in that format exactly to play with, but assuming you are using the PCL 5c driver, it should be a fairly simple task. If your using another driver (ie: RPCS) then it will be similar, just a little different looking dialog box.
Open your document, Select "Print", select "properties", you can change the "orientation", and "layout" (pages per sheet), 'duplex', and staple (assuming you have a booklet finisher installed and configured in your printer properties). There is an icon in the left corner that changes with the settings and should help you with the them. Obviously, you should only print 1 set, or even just a page or 2 to check the output. These types of things are always a bit of trial and error until you have done it a couple times. I hope this helps
2helpful
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Printing a booklet on WorkCentre 7345 , need help argent !!!
OK, same problem, I've gotten through the solution. I can print and have the first page and last page on one side of the large sheet and the two inside pages on the other side, so that is foldable into a booklet.
I start with a 4 page (US letter sized) document I wish to print as a booklet on tabloid paper.
In the (page layout or editing program's) print dialogue, I've said print all pages, set it at 1 page per sheet, then clicked the printer properties button to open the Xerox Workcenter 7345PS option dialogue.
In the Xerox dialog on the "Paper/Output" tab, selected the larger (Tabloid, 11x17" in my case) paper size, selected 2-Sided Print. Then I select the "Layout/Watermark" tab and clicked the Booklet Layout radio button, chose "Landscape" for the Page Layout Option. Note: I saved these settings as "Tabloid Booklet" by clicking the down-arrow to the right of "Driver Defaults" so that I could select them and not have to dial in every one of the settings whilst experimenting.
Printing 2 pages on landscape document
Usually if you see the page in the Publisher window is already landscape, it will go landscape in the Printpreview and also in the print out. I just try to imagine what is your problem.
If I am not mistaken, this is what you did:
You have two "small" pages (maybe A5??) and you want to print it in one page of A4. Of course the A4 should be landscape.
Publisher does not have the facility to set 2 pages A5 in one A4 like in Microsoft Word.
The easiest way is just create a new page with A4, then copy the 2 pages (or you called it flyers) and paste it in that A4 landscape page.
Publisher can do print 2 pages A5 in one sheet A4 but the arrangement is as booklet. You can see the choices in File --> Page Setup --> tab "Layout" --> scroll the Publication type.
I do print 2 pages A5 in one sheet with many variations using addition software named "Clickbook".
Let me know if I m wrong in interpret your problem.
3answers
Printing position of a picture
heyo Chuckie,
Really depends on your printer. I am assuming you are using Word. When looking at your documents, go to FILE, PRINT, click on PROPERTIES and then LAYOUT tab. THere is BORDERLESS printing. If you have a laser printer it may not have a problem with this, if you have an inkjet, there are paper rollers in the print that need to hold the paper while printing. As a last resort, I would make a PDF of the doc and swing over to Kinkos or a printing shop and print it off there.
Good Luck.
Wayne
Lost reverse side printing option
Yepperz
The double sided printing option relies on Status monitor working correctly. If information cannot travel from the printer to the computer, the option will be greyed out.
Make sure you have a direct connection to the computer without any hubs. If that doesn't work, try the following.
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
How do I print on both sides of my paper
On printers without a duplexer (a device that flips the paper to allow printing on both sides) you will have to print the first side, manually flip and print the second side. If you're using MS Word or MS Publisher you can easily configure the program to organize the pages for you: Start a new, blank document. -Click File, Page Setup then click the Margins tab. -In the Multiple pages section select Book fold. -Set your document to landscape orientation if it is not already. -In the Inside and Outside boxes, type or select the amount of space you want for your margins. -In the Sheets per booklet list select the number of pages you want to include in a single booklet. If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets. -When you get ready to print make sure you check the manual duplex box (should be in the first dialog box that appears when you click on File, Print). Word will print the first page, and then prompt you to take the pages that just printed and load them into the input tray of your printer. The trick is to learn how to orient the pages correctly for your printer. Good luck.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
