Amana 30" Self Cleaning Electric Range Stove W/ Oven Freestanding Black & Gray Logo
s
sally barron Posted on Oct 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I've done this 2 times already
My stove is not a Mayag Stove
Terry Hair
Level 3:
  • Amana Master 4,134 Answers
  • Posted on Oct 22, 2015
Terry Hair
Amana Master
Level 3:
Answers
4134
Questions
Helped
1092053
Points
16804
Hi Sally, let me try to help you. The category I am seeing is Amana 30" self-cleaning range. You are having clock setting issues. I need to know the model number to be able to research the issue and get back to you. Please add the model number with a comment on this question. Don't enter a new one as this will confuse others. I will get back to you as quick as I can with either an answer or to let you know what I can or can't find out on the issue.
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Bosch NET9652UC STOVE TOP shows Er 42
Er42 constantly slashing on my stove top, sometimes lasted for hours. When that happened you can't use the stove top until it stops. What should I do to stop the slashing?
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Water boiled over on the Right rear induction side. Stove shut off. Now the Right rear burner doesn't work and flashes and "F" when I set any temperature. Stove thinks I have the wrong type of...
Generally there is a number after the F. It sounds like some liquid got into the electrical, sometimes if you wait about a week for it to dry it will work. If not, you would need to call a service tech
always unplug electricity before attempting to repair on any electrical appliance
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 • Cooktops
2helpful
Streaky, filmy black stove top
Re: Streaks
After a final clean up with a a wet & well rinsed cloth buff the surface with a microfibre cloth & it will look like new.
If there re any difficult ares to remove use a glass cooktop
paste cleaner (from Sears, etc)then and finish off with the microfibre cloth.
May 25, 2009 • Cooktops
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Top Amana Cooktops Experts
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
