Question about Leisure Kitchen Ranges
The grill wont stay on
The control knob wont stay pressed in
5 Suggested Answers
SOURCE:
reddyanantha
  • 205 Answers
SOURCE: grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Posted on Oct 04, 2009
cadesertmax
  • 274 Answers
SOURCE: Sear knob will not stay on (very loose fit).
Pull the knob of of the sear burner valve shaft and check to see if it is melted on the inside, if it is, it will fit loose and needs to be replaced.
Posted on Jan 10, 2010
  • 3 Answers
SOURCE: westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Posted on Feb 16, 2012
  • 7 Answers
SOURCE: my oven wont stay on but grill still ok but they work off same knob
it could be the thermocouple, you can get uiversal thermocoulpe from mmost plumbers merchants , b and q etc.fairly easy to fit ,any probs drdrop me a line
Posted on Dec 06, 2012
I'm having problems keeping the grill lit on my BEKO dvg593-mk2 gas cooker. This has been a problem almost since new, i have to depress the gas knob, and keep it pressed for about 5-8 min's after ingn
Here is the owner's manual or try calling customer service at 0870-241-1321 for help. http://www.manualslib.com/manual/15108/Beko-Dvg593.html?page=3#manual
Feb 12, 2015 | Grilling
I have a stovesGG600 cannot turn on the grill the knob wont turn in that direction any more and i have to turn off the gas as it stays alight after using the oven do i need to replace the whole thermostst...
Sounds like you need to adjust the actual burner valve and not the thermostat control. If they are one in the same try adjusting it. Remove knob and look down the shaft there may be an allen adjusting screw in there
I’m happy to help further over the phone at https://www.6ya.com/expert/robert_24775b73ca70da93
Jun 10, 2014 | Stoves Newhome ECH600MXa Electric Kitchen...
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
The smoker burner wont stay lit on my grill. I can get it lit but it wont stay on
I had the same problem and I found that if I tightened the thermocouple line on the back of the smoker control knob it would work properly. You can see the thermocouple line brass nut thru the slotted opening just above the double doors and below the control knobs. Mine was only finger tight and as soon as I tightened the thermocouple line nut, everything worked normal. Good Luck
May 09, 2012 | Brinkmann 5 Burner with Smoker 8101750S
Westinghouse oven LPG 527 wont stay alight and grill wont start
Feb 16, 2012 | Ovens
Baby weber flame will not adjust to different levels stays on high flame even when we turn the knob
You will need to replace the control knob assembly. Which includes the tank hook up & regulator. Contact Weber Customer Service @ 1-800-446-1071 for this part.
Hope this helped you.
Jul 06, 2011 | Weber Baby Q Grill
Sear knob will not stay on (very loose fit). Other knobs seem tighter fit. The grill is brand new -- thus disappointed by post assembly quality control.
Dec 30, 2009 | Weber Summit S-470 Propane Grill
Kitchen Ranges Logo
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
