It keeps showing incorrect password,but it works on the other tablet
I don't know what you are being told, but getting rude with us will not get you the help you wish for. If everything were working as YOU state, then there should not be a problem in the first place. However, there apparently IS a problem, and assuming it is not "operator error" (meaning YOU), then we will make suggestions that you can check on and try to get past this problem. It IS possible that the tablet itself is defective and won't connect whatever you try. But since it SEEMS to be making the effort, I would sort of lean in another direction. While it may seem that the password is the problem, occasionally, it is the router, or better stated, the router configuration, that is to blame. Does your router (the one you are trying to connect to) use MAC filtering? If so, the MAC address of the tablet would need to be entered into the table in the router before the router will accept the connection form the tablet. Without that, it would appear to simply be an incorrect password entry as you describe. If that is not the case, then be sure you are attempting to connect using the proper form of encryption on the tablet. Many older units use the old WEP encryption, which most routers do not acknowledge any longer. Ensure you are using WPA or WPA2, whichever the router is set up for.
