Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
J
Jeff Bexten Posted on Oct 21, 2015
Lamp and temp lights flashing
Replaced lamp
5 Related Answers
Silvia Kimbrough
  • Posted on Jun 06, 2008
SOURCE: t.v. will not turn on. flahes "lamp" then no picture!
I have a picture but the tv will periodically turn itself off during the day and then flash the 3 blinking lights...anyone know what the problem could be. We can fix it ourselves if we knew for sure what it is.
TONY BIGNELL
  • 147 Answers
  • Posted on Apr 15, 2009
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Anonymous
  • Posted on May 15, 2009
SOURCE: Have replaced Lamp and still does same thing.
I replaced the ballast, a solution not even mentioned by the 3 Experts I was referred to.
Anonymous
  • 90 Answers
  • Posted on Jul 09, 2009
SOURCE: Samsung HLN467W 46 in. Rear Projection HDTV
I would suggest replacing the Lamp
Anonymous
  • 16 Answers
  • Posted on May 07, 2010
SOURCE: Samsung DLS not working(with new lamp)
The grinding sound is most likely the color wheel. The lamp will not fire up if the computer senses the color wheel is not in motion or turning too slowly. It does this to protect the color wheel from being burned.
Something else you need to realize is the fans sometimes make some noise(especially the fan at the rear of the DMD Board).
The Ballast does not go bad that often and is misdiagnosed more times than it actually needs to be replaced. Sometimes the DMD Board is defective and won't send the color wheel the signal to start which in turn doesn't let the lamp turn on. I have read this misdiagnosed as a bad lamp, ballast, and color wheel multiple times. I currently have two of these in my shop at the moment and they were both verified by swapping known good DMD Boards.
There is some very good information available on this site but many times it isn't that simple of a repair. You need to get all the information and verify before buying parts. Most of the time it will pay for someone to have a reputable shop do a repair rather than buy parts that are not needed. I have had three people buy lamps in the last week, and two replace capacitors, only to give me a call and fix the problem correctly. All of these people got the repair tips from the internet.
2helpful
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
TV went off, and three lights come on (green "power", red "temp", and red "lamp")for just a second, in succession from left to right.
My television had two red lights flashing, one for Temp and the other for the lamp. I removed mythe lamp assembly and the bulb filament was burnt out. I order a new lamp and housing unit UX21517 and replaced it and now I have the red light flashing which is calling out the lamp again.
2helpful
3answers
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
1helpful
3answers
LAMP LIGHT ON AND TEMP LIGHT, TELE WILL NOT COMME BACK ON
Look in the owner's manual. These lights indicate the current condition. Usually the lamp light will go on if the lamp has failed and similarly the temp light if the fan has failed. With both, there may be a different problem. If you can confirm your model number, I can look up the problem indication as well.
Thanks,
Dan
2answers
Lamp goes off and tv shuts down after lamp replacement
CK FAN on LAMP,or you could have problem with Ballast.
Htachi Rear Projection Picture/Sound Lost
If you never replaced the lamp it may be time.4 years to run on 1 lamp is a good run.If you were having no other problems I would say it`s safe to say that will solve your problem
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
