With a Simplex copying, it is copied at the right position. But when I make a Duplex copying,it is copied at the wrong position only on the front side. The back side is copied at the right position. The Front side is copied at 2.5mm upper direction. This problem occurs with a Duplex printing, too. I executed the SIM 50-28, but I was not able to adjust it. Which SIM-Code do I have to execute? Please tell me.
Check that you are using duplex and left binding. also does this happen with other files??? does it happen with different program pdf , word etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Upper feeder tray copies work fine, main feeder does not print, makes odd noise
Found the answer.
Problem:
Wide blank area on Lead Edge, or Misregistration possibly accompanied by noise. The noise may be described as a clicking, buzzing noise while making copies. The noise may stop for short periods while making copies.
Cause:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position.
Solution:
Free the Spring, by rotating it. Ensure that the Pawl moves freely in and out, and engages with the clutch.
SOURCE: vertical strip of black lines on copy
PULL THE INK CARTRIDGES OUT AND VERY GENTLY WIPE THE CIRCUIT BOARDS LOCATED ON THE BOTTOM WITH A VERY SOFT CLOTH ....THEN GO THRU THE CLEAN UP MODE IN THE OPTIONS .
SOURCE: sharp 5516 n legal duplex copying is not coming
Duplex unite only use a4 size not other size.You can try other size before configure.
SOURCE: only copies half a page. Right margin cuts off
check paper trays to make shure paper is tight in guides. registration settings off
SOURCE: Colored lines are printing on the printed copies.
When this happens, you need to clean the scanning area. When you lift the top cover, you will see a green clip on the right hand side (of the actual cover) and you clean the scanning section on the left hand side on both the bottom of the cover and on the base where you would put your original copies.
Then open where you put the toners in, and pull out on the green rods a few times each, and this will help clear the grid.
