Kenmore 3/4 hp Food Waste Disposer Logo
K
Kevin Franey Posted on Oct 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kemore 3/4 hp disposal that I have to reach under a hold the black top To get it going. Otherwise it clicks or nothing at all to often
Gene Haynes
Level 3:
  • Kenmore Master 5,391 Answers
  • Posted on Oct 11, 2018
Gene Haynes
Kenmore Master
Level 3:
Answers
5391
Questions
0
Helped
2606697
Points
14124
How to fix a stuffed garbage disposal?
It should have come with a Allen wrench. Be sure it is off. Insert it in the bottom into the center hole. Move it back and forth several times until it frees up. Remove wrench and try, you may have to do this several times. Also be sure the unit is reset before turning on. If it does nothing nor makes nay noise it is probably tripped.
It will work but it sounds like metal is grinding in it.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Use vacuum cleaner to see if something is loose.
Otherwise, a noisy disposal that works is functional and not dangerous... but annoying.
Life of disposal is probably shortened since the bearing seal could have failed letting water in, and bearings could be rusted.
Replace disposal if noise bother you.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Item stuck in garbage disposer
Use vacuum cleaner?
Remove rubber from top and see if you can ge needle nose vice grips onto the object.
Use broomstick and see if you can rotate cutter disk.
Gene
Kemore garbage disposal 6010 repair jammed
Use broomstick to un-jam the disposal cutter disc
Or use allan wrench on bottom of disposal
Following link has illustrations and tips for repairing disposal:
Gene
Water Heater Timers Save Money
All of a sudden I am hearing a clicking noise and I can't find anything stuck or loose. It is rotating but making this noise,
Disposal parts get loose... as long as disposal is working, it is ok
Clean out with vacuum cleaner to remove stray parts etc
Gene
Replace garbage disposal shredder disc
Which direction does disposal blade turn?
For example when looking straight-on at the nut holding power saw blade, the blade rotates counterclockwise, so the nut is reverse thread.
Most disposals are not made for repairs
Add a comment and say where you are getting the parts and which model
Top Kenmore Garbage Disposals Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kenmore Garbage Disposal Expert? Answer questions, earn points and help others
