The
barcode must be a Code 39
barcode, not a Code 39 Extended or Full ASCII
barcode. The Enable Code 39 Full ASCII must be scanned from the
Symbologies section of the
LS2208 Product Reference Guide (page 186 of 342). The Enable Function Key Mapping
barcodes would have to be scanned if you are seeing something other than the tab happen when you scan into your application. In Word, for instance you will see the
italics enable/disbled whenever the $I is encountered in the
barcode.
As for the Covert to Code 39 Full ASCII- that is for Wand and Scanner emulation. The setting was having no effect because you were not connecting to either of these hosts.
