Fitbit Zip Wireless Activity Tracker, Midnight Blue Logo
B
Bonnie Shaffer Posted on Oct 19, 2015
Will not keep time or my steps
Started 3.5 days ago and i put a new battery in it 3 days ago, do i need a new one. it is less than a year old
Rich Laue
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Nov 02, 2015
Rich Laue
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
54698
Points
27
Good question, are we referring to the Fitbit Zip?
If so I would remove the battery for 10 seconds then replace, this will restart the unit.
  • Rich Laue
    Rich Laue Nov 02, 2015
Battery goes dead within a couple of days without use
batteries fail over time and should be replaced even rechargeable batteries
never change just one battery as it will discharge into the flat battery
keep the batteries full charged at all times and remove them from the camera when not in use
HELP with my problem to my Question and added details
A good hot battery shoulde do it. Have you had any problems with the security system? That's all that should keep it from starting now. Have you put a socket on the crank bolt to make sure the engine is not seized and turns freely?
Good luck.
2answers
Randomly won't start
Change the crank censer
Battery needs jump start if car is not driven for 3 days.
u either have a shorted cell in the battery or the system has a current draw like a glove box light being left on, try disconnecting the battery the next time you leave it, if it starts ok then u have a current draw and need to find the source of that draw.
2helpful
Ford Escape Hybrid goes dead if not driven for 3 days straight
I have the same problem with my 2007 Escape Hybrid... First experienced it about 1 year ago. The vehicle produces periodic sounds like an electric motor running for several seconds. I believe this is from the motor driven safety relay that disconnects and reconnects the high voltage hybrid battery when the vehicle is not in use. I also can hear a high frequency scream that sounds like a switching inverter power supply. If the vehicle is unused for a day or two the 12V battery is discharged and a jump is needed to start the engine. Ford service could not diagnose the problem. The +12V battery tested OK, but since it was almost 3 years old it was replaced anyway. This helped for a while, but the problem returned after I recently left the vehicle unused for several days. I know the battery is good, it tests OK and is less than one year old! Somewhat reluctant to go back to the same Ford service agency because of their previous failure to fix it. Please advise if you have found a solution or have additional information. This is the only problem I have ever had with the hybrid Escape, but it is very annoying. I am forced to carry a jumper battery to make sure I don't get stranded.
Coffee pot leaking
Your brewer has a 3 year warranty. If you will call customer service with the model and code date and it is less than 3 years old, we will replace it with a new machine at no cost. If it is over 3 years old, we will replace it at a reduced price.
Top Fitbit Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Fitbit Tool and Hardware - Other Expert? Answer questions, earn points and help others
