Backup camera worked for a about a week after the torque converter was replaced. Then it stopped working again. Software has been flashed and reprogrammed to latest factory.
SOURCE: I need a 1998 Dodge Grand Caravan serpentine belt diagram.
The belt routing diagram is shown on a decal located on thehorizontal metal support above the radiator and under the hood support rod (passenger's side near the coolant overflow tank).
PT Stanley
SOURCE: Need serpentine belt routing diagram for 1994 Dodge grand caravan
3.3L?
Looking at the engine from front (right side of the Van): Stating at the Top, Going Left to Right and Clockwise:
Over the Alternator
To under the Idle Pulley,
To Over the AC Compressor.
To the Left Side of the Water Pump.
To the Right side and Under the Crankshaft Pulley
To the Right side and Over and Down the Tensioner
To Under the Power Steering Pump
And Back up-to the Left side of the Alternator.
Advise when puting it on:
Put the Belt around everything else accept for the Alternator. After it is around all the rest of the Pulleys - Pull the belt up - tight from the Power steering Pump and the Idle Pulley to form a loop, holding the Belt close to the Altenator Pulley.
Using the 15mm wrench or belt tensioner bar - rotate the Tensioner Pulley towards the front of the Van and then place the belt over the Alternator.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.com!
SOURCE: vacuum diagram 1998 dodge grand caravan
Hi there:
I suggest check this image about engine vacuum diagram for the 3.3L and 3.8L engines - 1997-99...
Hope this helps; also keep in mind that your feedback is important
and I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
