Televison & Video Logo
Rebecca Lippert Posted on Oct 18, 2015
Toshiba tv/vcr (2001) won't rewind...fix or toss!?
  • Sharon Williams Sep 07, 2019
    Do you an original remote with your tv
    Try a tape head cleaner or long q-tip dipped in alcohol to clean I side workings of vcr.
Michael Gobel
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 07, 2019
Michael Gobel
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
5
Questions
0
Helped
2547
Points
10
Cheaper to toss, unless you have a rewind machine. Goodwill, Salvation Army or "Vinny's" (St. Vincent DePaul) might have one for $5 or $10 max. Plus, the hassel of getting parts nowdays.
1helpful
Magnavox dv220mw9 the vcr player won't play
Someone will have to open the unit to see what is happening---either tape is not loading all the way or when FF or Rewind hit not moving the reels----could be as simple as a belt or a bad drive idler (most use either a rubber wheel or gears to move the tape in Play, FF, and Rewind.
3answers
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
3helpful
2answers
PLAYER SWITCHES OFF WHEN PLAYIING VHS TAPES
check any mechanical failure in the vcr unit. like tape won't work properly might some obstruction or plastic broken.
2answers
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Actually, it's an MW24FP3 VCR unresponsive
After Checking Toshiba FAQ, it turns out that the record button must be turned off to do anything, including playback.
1helpful
Sony VCR rewind and counter problem
The belts are slipping. Every 5 years is about right for replacing them all.
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
