SOURCE: fat max laser is in inches need feet
Press and hold the "+ - units" button and hold for over one second. It should then let you select your units of measure. In this case it should be the second selection, which is "0.00 ft". If you lost your owners manual, you can download one at www.engineersupply.com/Manual-and-Help-Docs/Stanley-TLM100-Manuals.pdf. If you find this helpful, please rank the solution.
SOURCE: Just purchased a Stanley FatMax 10-778 retractable
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Testimonial: "Thanks so much!"
SOURCE: cant put the thing back
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
SOURCE: looking for instruction manual for Stanley Fat Max
The manual is available at the Stanley support site: http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-5162309471456573043/view_document!PAGETYPE?sq=FatMax%2b77-189&sc=2&sf=101113&sg=1&st=405165&documentid=342296&action=view . The direct link is: http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-5162309471456573043/!DOWNLOAD?entryid=342296&attachid=29375 (but I'm not sure this will work).
If you have problems with those links, start at: http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-6221370935515628266/front_page!PAGETYPE?category=2 . Enter 77-189 in the search box and then click on the link.
I hope this helps.
