Re: How i connect my sony ic recorder icd b16 to a...
There is a audio in jack on most computers. Get an aux cable and Software to record the sound off of recorder. You will need to let it play all the sound to recorde it. So if you recorded 1hr of sound it will take 1hr to recorde it to computer.
Sony IC RECORDER ICD BX-800 (!without USB connection!) What you need: - newests audio drivers in Windows 7 (updated audio-drivers) - audio cable 3,5 M (male) both ends M-M (male-male) - freeware application Audacity for Windows (with LAME)
Howto step by step: - one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800 - other end of audio cable connect to PC/notebook microphone (or LINE IN) - nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default) - in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1) - in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"! - Audio Host: MME - Output Device set "Speakers (Audio device)" - Input Channels set "2 (Stereo) Input" - Sampling (Hz) set 44100
As there is no USB port on this IC Recorder, you can connect the Headphone OUT of the IC Recorder to the LINE IN of the Computer. Then, use any Sound Recorder Software to capture the files. You can also use the Sound Recorder Software preinstalled in the Computer.
After transferring the recordings to the Computer, you can use any CD Burning Software to burn the files to a CD.
I solved the problem by connecting my Sony IC Recorder to the USB port on my McBook Pro computer and then emptying the trash can on the Mac computer. Visually (flashing red indicator light) and audibly (the recorder's sound that indicates something being erased), it was clear that mp3 files were finally, really being erased on the Sony recorder even though the recorder's own screen display had previously shown only empty folders and no files. Dragging files to the trash can doesn't really erase them unless you also empty the trash. All dragging to the trash can does is somehow mark the files in a way that, unfortunately, makes them invisible to Sony's file detection system.
I have found conflicting information on this recorder. According to product specs on Amazon.comUK This recorder has no computer connection.
If this product description is wrong you should see a USB connection somewhere on the recorder. Just connect the USB cable from recorder to your computer. If you did not receive a USB cable with your recorder you will have to buy one. You will have to determine if you need a mini or regular USB cable. Then double click on my computer. You should see the device listed there. Double click on the Sony device icon. The files on your recorder should now be showing. You should then be able to drag the files to a folder of your choosing on your computer.
An adapter will not fix the problem. The files cannot be transferred to a computer using a USB port. The files must be transferred analog using the recorder's headphone cord. The files are then recorded to the computer from the Sony recorder using a program such as Windows Recorder. The ICD-B500 has many great features but archiving to a computer is not one of them.
This IC Recorder doesn't feature the USB port. However, you can transfer the files by connecting the Headphone OUT of
Recording Software. You can also use the Sound Recorder Software that is
pre installed in the Windows Operating System.
