When trying to push a wash cycle the following buttons light up and we are unable to change. The autoclean, rinse only, steam sanitize and delay hours(2). I've disconnected the power supply and tried to see if the control panel would reset, this did not do anything. we have a Maytag 575-2 MOD# MDB6769P4WO, Serial# F21302382
Hello. From the symptoms you describe, the problem might be a defective control panel. First, make sure the control lock is not enabled!! Look for a button that has a "key" symbol or the word "lock" underneath it. Touch and hold for 5 seconds until the lock is disabled. The part numbers for the different styles of the dishwasher for the control panel are:
BLACK--W10329522
WHITE--W10329521
BISQUE--W10329523
STAINLESS--W10329524
The touch control panels can become damaged from a variety of causes. Power surges(Have you had an outage in the last 3-4 weeks!?), defective components, moisture invasion, etc. are the most common culprits. If a button is "electrically stuck"(i.e. the computer thinks you're still pressing it), nothing else will work until the button is released. It is just like any other appliance with physical buttons(soft touch for example on a microwave or range). Now, if the dishwasher actually starts when you press the start button, then the problem lies with the main control board(part# W10352588)--remember--a stuck button will prevent any other action until it's released. The troubleshooting on this unit is relatively complicated--when diagnostic mode is entered, the clean light will flash a certain number of times for the first part of an error code(function code, then it will flash again a certain number for the second part, problem code,(ex. blink 6 times, wait, blink 1 time). There is an error code chart that has the meanings to the different sequences--(ex. a 6-1 is inlet water valve(function), and then "no water"(problem). You press the start button to advance to the next stored error code. Power off the unit to go back to normal mode. If you are hesitant about performing any of the troubleshooting, call for service! I hope this helps you!
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
SOURCE: Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
I suspect for either of these units that the timer control boards are bad.
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
SOURCE: Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
