Both the top and bottom oven lights flash at the same time and the oven are unusable. If I unplug them it may work for a few days but then it happens again. Currently it is becoming more regular.
SOURCE: oven not heating up.
fault is the circular element found the fan. take back plate off inside oven and element is exposed. often but not always, you can see the damage to the element. element is easy to replace - usually held in by 2 - 7mm nuts on posts from the element base plate
SOURCE: Stoves Q900 GRF DO fan assisted gas double oven
hi everyone, i hope this helps.
you may need to take the oven out and use a vacuum cleaner to **** out the dust from the back of the oven, i found that this is the cause for ovens not lighting and grill not working, its a simple thing to do, just pull the oven out and at the back you will see where all th dust has accumulated, just vacuum it out
and it should work. i have had so many problems that i am going to replace the whole piece of **** now that the fans have packed up !
stoves know that the ovens are rubbish and unreliable, but have done nothing to help (even the engineers know this)
SOURCE: Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
SOURCE: Fan oven is dead
When you turn to oven thermostat on, does the dial illuminate? All the information you need is in the handbook. If you don't have a copy, supply an email address and you can then gain access to by BT Digital Vault where a copy is stored for you to access.
SOURCE: I have a stoves 720 gra with both ovens working ok
good day,
hope this link below will solve your problem.
ovens
