When I plug the TV in, and before I turn it on, a single loud click sound comes from the bottom left of the TV. About 10 seconds later I hear a softer click sound come from the TV like the sound I would get when I turned the TV off when it was working properly. These sounds do not occur if I plug the TV out and then back in with a minute or so. The TV also does not power up and give me a normal picture for a second either when I plug the TV out and then back in within a minute it goes straight to standby.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
SOURCE: screen went black no sound no picture when i turn
How many times red light blinks? It is error code of problem in TV.
There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
SOURCE: Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
SOURCE: The screen blanks out after approximately 20 minutes.
The power supply board is dead.Those high voltage transformers on the power supply board,one those power coil have a short in it,that why it cause this shutdown a have a loud electrical current noises.Tries websites like Shopjimmy.com.Ebay.com to buy a new refurbish power supply board for the replacement,should solved this loud electrical noises shutdown to tv.
SOURCE: When TV is turned on,
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
SOURCE: red light flashes 8 times
I went to servicemanuals.net and downloaded the complete service manual for this TV and found that 8 blinks means you need to check out the Panasonic-txnss1rltu-ss-board which I have had to replace once before on this set. I have found further that this item is prone to short life as a result of inadequate ventilation problems. Anyway, the part I need was easy enough to find in the service manual and ShopJimmy has it for about $43. So my problem is solved now.
Five blinks - AKB
circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on
the A board. In addition, unit could be in IK blanking, try turning
up screen A2 slightly.
