Pride Victory 10 4-Wheel Electric Scooter Logo
A
Anonymous Posted on Oct 16, 2015
Where is the horn located, and can i install a louder horn?
Rob Hill
Level 3:
  • Pride Master 1,480 Answers
  • Posted on Oct 18, 2015
Rob Hill
Pride Master
Level 3:
Answers
1480
Questions
0
Helped
518153
Points
3838
Hi, i do suggest you install a additional horn...
Need help ?, i do such a thing ...
Regards
Rob
Where is the horn located on a 2007 hd 883l sportster?
press horn button and listen for location
Mar 02, 2014 • Motorcycles
1helpful
2007 harley davidson sportster 883l horn
Usually right below the head light assembly.
1helpful
Hi how can I install an ooga horn on my yamaha r1 04 ????
Just like any other electrical horn. A relay is recommended for any after-market horn as they commonly require much more power than stock (you can find relay wiring diagrams and instructions all over the InterWebS). Other than that it's a question of finding enough room for it behind the fairing (be careful not to block the fork or wheel movement). If loudness is what you are aiming at, there are much better and more compact horns than ooga. Look for compact dual air horns (like Stebel, for example, very loud) or two tone electric horns (considerably louder and better sounding than stock). Ooga will make most people laugh instead of brake or flee, IMO.
Nov 09, 2013 • Motorcycles
Replacing kia amanti horn
https://onlinerepairmanuals.com/workshop/kia/amanti
https://www.carmanualsonline.info/b/kia/amanti
https://www.manualslib.com/products/Kia-Amanti-3908909.html
To replace the horn on your Kia Amanti, you will need to follow these steps:
Disconnect the battery: Before you start working on the horn, disconnect the battery to avoid any electrical accidents.
Locate the horn: The horn is usually located behind the front bumper or under the hood of the car behind the front grille. You can refer to your car's manual to find the exact location of the horn. Hopefully, you won't have to take off a body panel to gain access.
Remove the old horn: Once you have located the horn, remove it by unplugging the electrical connector and unscrewing the mounting bolts.
Install the new horn: Install the new horn by screwing in the mounting bolts and plugging in the electrical connector.
Reconnect the battery: After you have installed the new horn, reconnect the battery and test the horn to ensure it is working properly.
If you are not comfortable performing these steps yourself, you can take your car to a certified mechanic. According to YourMechanic, the average cost for a Kia Amanti horn replacement is $113, with $18 for parts and $95 for labor. Prices may vary depending on your location.
2helpful
2011 Ford Fiesta horn. Want to replace with a louder horn. Can't locate it.
It is mounted underneath the right-hand headlight unit.
3helpful
How do i install a new louder horn for my scooter? i have a bosch 30amp relay, a switch and the electronic horn.
First you will have to determine if your horn activates by earthing via the horn button or by connecting to positive via the horn button.
Locate the old horn and remove its wires. Connect these wires to the relay on pins 85 and 86. Operate the horn button and the relay should click.
Run a new wire from battery positive to relay pin 30.
Run a new wire from pin 87 to the horn positive.
Run a new wire from horn negative to an earthing point close to the horn or to battery negative and you're done.
1helpful
2005 Nissan 1400 Standard. The hooter buttons on the steering wheel works intermittently. The ******* themselves work OK. I would like to know what to look for?
First locate the horn in the engine compartment should be between the front grill and radiator core support. Pull the horn off, it has one wire and one bolt holding it on. next clean the bolt area where it is bolted on with sand paper to get a good ground. Sand it on the bottom of the mounting bracket and on the area where the horn bolts on. next get a wire and hook to the positive side of the battery, touch the horn to the negative side so it has a ground then touch the horn wire connector with the wire connected to the positive side of the wire does the horn work? if so it was needing cleaning, if not you will need to replace the horn. There are two things that you can do before you replace it look for a single screw on the horn and back it out three or four turns the try it again before installing, if this makes it work better then you know the problem that the reeds are going out replace the horn for $15.00 at any auto parts store. Or buy a air horn for $20.00 bucks and replace it with that, it's louder and easy to install. Nissan has always had issues with the horn so your not alone on this issue. Also check to see if a wasp built a next inside the horn or a mud dauber may have built a nest in the horn, if there is obstruction in the throat of the horn clean it out and try it again. Of all Nissan's I have worked on I have found it necessary to replace the horn about 90% of the time.
1helpful
2answers
Location of a 2003 dodge stratus horn, also not loud enough
Horns are usually in front of the radiator and behind the grill--look for two of them, one on each side. Make sure they both sound. If only one works, there is a significant reduction in sound level. There may be road debris stuffed into the horn's throats--poke a hooked stiff wire into the throats and see if anything comes out. Most are sealed and can't be taken apart to clean--replacement is about the only recourse. (look in a wrecking yard for replacements)
3answers
Horn wont work
Unplug the wire to the horn and make sure you have the horn grounded really good. Take a hot wire and run it from the battery to the horn. touch the hot wire to the end of the horn and see if it works. If it does not work then you need to replace the horn. If the horn works then take a test light and hook it up to the horn wire and have someone push the horn down. you should have a hot wire. If you don't them check the horn fuse. Let me know if this works.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
