HP LaserJet 1320 Printer Logo
Posted on Nov 16, 2007
Laserjet 1320 shows undocumented light pattern, won't respond
When I power up the printer it doesn't go into its initialisation routine - the toner light is off, the attention light in on, and the ready & go lights are flashing. The printer will not respond to any buttons being pushed.
  • 2 more comments
  • CrazyLouie Jan 11, 2008
    My error code is not in the manual and Hp wants money to tell me that I probably need a new printer.
    Does anyone know when the amber warning light comes on steady and both the green start push button and the green ready light blinks together. When I turn on the power, and stays that way.
    Thanks for any info, CrazyLou
  • Anonymous Jan 21, 2008
    I have the same problem - and have no idea what to do. My printer is sitting in the cupboard.
  • outlawde Feb 14, 2008
    I have the same problem. The printer was working fine the the toner light came on and the go and ready light started blinking. I have tried the same things but nothing is working.
  • Tony F Feb 23, 2009
    I have the same issue and light pattern. If I open/close the cover, the engine runs. I open the left side cover and pressed the little button for the Engine Test and it printed a test page with lines.
    Any suggestions?
A
Anonymous
Hp laserjet 1320 toner empty?
you might try a recycled cartridge and have a lot less invested.Sounds like your cartridge is empty.Is print quality bad or light?
1helpful
3answers
HP 1320 Prints Blank Pages
HP 1320 Prints Blank Pages Problem with the HP LaserJet 1320 Printer
1helpful
HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
Hello sir.I am Dnyaneshwar,I am using Hp laserjet 1320 printer. when I'll print the page it can't page to print and automatically centre light is started.
Make sure the toner is not empty just remove the toner and shake it and installed it if the problem is continue then replace the toner.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
2helpful
2answers
The Attention, Ready, and GO LEDs are on solid
Here is service manual for HP 1160/1320 series ->http://filecom.net/CXW_R.
Solution is on page 34. I hope it will help you.
Hp Laserjet 1320 toner rubs off page
when the toner rubs off means it wasnt fused which means you need to replace the fuser
3helpful
6answers
HP Laserjet 1320n Error Lights not in Manual SPAM LOSERS CAN BE FOUND AT 1*800*532*4187
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
3answers
Problem HP 1320 not responding
Try changing to a new USB cable
4helpful
4answers
Hp laserjet 1320 problem
This is an error state that is not described at HP site.
Try to do a hard reset:
1) Turn off the printer
2) Press and hold down the green GO button
3) Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
4) Release the GO button.NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
5) The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Hope it will help you
k24674
Grand Canyon Tech
Grand Canyon Tech
