Sewing Machines Logo
Rita Adams Posted on Oct 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore sewing machine 385.16221 bobbin winder nut stopper is broken
The bobbin winder stopper or nut does not work and there are no parts at Sears. How can I fix or replace this part? This is the small teardrop shaped part that is on top of the machine adjacent to bobbin winder. It stops the thread when bobbin is full. Thanks
Danny Kuhlmann
Level 3:
  • Kenmore Master 1,443 Answers
  • Posted on Oct 27, 2015
Danny Kuhlmann
Kenmore Master
Level 3:
Answers
1443
Questions
Helped
262355
Points
4794
Hello, Here is the website for the part you need.
Bobbin Winder Kenmore KM1368
1helpful
The bobbin winding mechanism on my Sears Kenmore model 2142 doesn't work. I have to wind my bobbins by hand! How do I fix this feature?
If you don't want to pay for a service call, you can purchase a handy implement (a stand-alone bobbin winder) for about $30 at the local fabric store or online.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Model 2142. Motor runs but why doesn't belt move for regular sewing?
Make sure the bobbin winder has not been activated. When the bobbin winder is activated, the needle bar is deactivated. The belt could also be stretched, damaged, or broken.
If it is a mechanical machine, how long has it been since a thorough cleaning and oiling?
It was working now it seems to be frozen the needle part wont move
3answers
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
2helpful
2answers
On kenmore 385.18221 sewing machine the bobbin winder stopper nut fell off. Now thread winds unevenly on bobbin. Can I take top off machine and replace the nut?
yes that should be an easy fix for you to do. Just make sure you remember which screws came off of where and that all of them get back in the same places. no "extras" good luck
Bobbin rewinder won't work
it's possible that there is a part inside the machine that could be broken, it would be a good idea to have the machine checked.
Need bobbin winding ring for Sears Kenmore model # 148.12140, no longer avail at parts online. Is this ring available anywhere else?
part number 1939 Looks like a normal bobbin winder friction ring. Try sew classic. they have some generic ones in a few different sizes. (btw.... looks like a Janome one might fit, but I didn't find it)
http://shop.sew-classic.com/Bobbin-Winder-Parts-Rings-Tires_c16.htm
2helpful
Bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at sewusa.com.
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
BOBBIN WINDER WON'T WIND
bobbin wont wind on sewing machine
Top Kenmore Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
