SOURCE: How do you check/adjustthe diesel injection timing
You should not have to adjust the timing.If it's not running good then you either have a fuel problem[plugged fuel filter or leaking rubber fuel lines]or you need to check the injecters.To check them start the engine and loosen the injecter lines on the injecters one at a time to determine which injecter needs to be replaced.The injecter that makes no differance to the way the engine sounds is the one you need to replace.
