Quit heating so I bought the new heater spiral unit and two limiter temperture sensors... cleaned the dryer vent from front to rear and out the wall very well... now it will run only a couple min heats up fine but shuts off with ERR-1 no matter what dry setting I use. please help
Check the exhaust pipe for a clog. Outside of the machine by the vent you should feel the rush of hot, moisture laden air coming out. When the hot exhaust does not leave the machine as intended and collects, raising the temperatures inordinately and causing it to overheat and shut down.
U might try bypassing the temp limiter sensors to see if unit continues to operate.
SOURCE: Runs but no heat
i have replaced TH2 in my dle0322 about 6 times now. It never lasts more than a month. What could be causing this?
SOURCE: Maytag MDG16CSBWW heating problem
HI thanks for the question. well ,you changed all the parts you needed to. but clean the venting from back, to the outside. thanks. please rate my answer. thanks.
SOURCE: front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
SOURCE: dryer keeps shutting off
maybe there is a sensor or a thermostate in it? check owners manual or call the company? just a thought.
SOURCE: Cleaned vents, dryer gets very hot, shuts off w/o drying clothes
Sounds like a faulty operating thermostat. Only way is to test on a electric griddle that you can set the temperature to 150 deg and measure with a ohm meter.
