Moultrie Game Spy M-880 Logo
T
Terry Colin Posted on Oct 13, 2015
Aim light staying on - Moultrie Game Spy M-880
530IN pilot light lights but the fireplace won't stay on
This problem usually has a thermocouple related cause.
Thermocouple failed,
Pilot light too low or aimed wrong to heat the bulb.
Thermocouple bulb has slipped out of the retaining clip or bracket.
2answers
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Not firing up
Try cleaning the thermocoulpe. If its dirty and sooty no enough heat gets to it and the pilot won't stay on. Also make sure its aime inside the hottest part of the flame. The small blue tip of the flame.
Remote dont work i change the batteries and lights stays on
U can test the remote if good or not through using camera.Try to aim the remote sensor to the camera and press any button of your remote.You see a lights coming from the sensor of the remote mean the remote is good.if not lights on when pressing the button of remote mean not good.repalce battery or the photo sensor of remote.
I bought a dusk to dawn light, and when I put it in it will come on and stay on for about 10 seconds and then go off and stay off for about 10 seconds, then it comes on again, it keeps going off and on, it...
If you aim the light anywhere near the sensor, then everytime the light goes on, the sensor thinks it is dawn and shuts it off again. Of course then the sensor thinks it is dusk so turns it back on again.
Make sure the sensor is blocked from the light. Cover it with a thin diffuser if you have to.
Sony Playstation 3 when turn on every thing works but the blue light stays on all the time with out game inside it and it wont take games i was playing then it just quit and would not eject my game when it...
Your blu ray drive is defective. Go on ebay and buy another. You can replace yourself. It voide the warranty though
I have a guide to help if needed, or I can do it for you. let me know.
AIM = DBurch1102
Chamberlain garage door will not close
See if both sensors stay lit until the door reaches the closed position.
If either light is off or flickers the door will go back up. Try aiming the eyes very carefully. If they are aimed properly. Check the wiring if you move the wires and the light flickers you have a bad connection. If the lights don't come on you may have a broken wire.
9helpful
2answers
Opel astra headlight adjustment
two screws on each headlight control the direction the headlights are aimed. One screw, usually at the top but sometimes below the headlight, adjusts the headlight up and down. The other screw, located to one side, controls the headlight from right to left. Turning the appropriate screw one direction or the other will change the direction the headlight points.
In order to aim your headlights you need to have a flat vertical surface you can aim your headlights at in front of a level surface on which to park the car. If your driveway is level your garage door is the perfect place to aim your headlights.
The tools you will need for this job are simple. Masking tape is used to mark where the headlights are to be aimed and a screwdriver is needed to adjust the headlights. A tape measure will be necessary to measure the distance of the vehicle to the surface you're using to check the aim and to measure the up and down distances from your marks
Having troulbe signing into the aim saying communication errror
AIM's last update screwed alot of people because the adapted it to be compatible to Vista. Not everyone has the issue but lot of people do. my solution would be to download trillian from cnet.com it's an IM program that combines AIM,Yahoo,ICQ etc... All of your friends will still see you the same way and comunication stays the same too. if you try it let me know how it works out for you. don't forget to uninstall AIM because you wont need it anymore.
3helpful
Cannot go on AIM
i had the same problem...when someone would send me a text from aim it would show, but just stay stuck on that main screen....what i did was go to aim....then put in my cell phone number...and sent myself a message...then it came in my inbox on my phone...finally my aim was visible with all my buddies...hope this works for you too!!
Top Moultrie Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
