Sewing Machines Logo
A
Anonymous Posted on Oct 13, 2015
How do I find and install a driver for my Janome 10000 Plus it is a 3.0 version I want it to be compatible with my windows 7
Darlene Campbell
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 20, 2019
Darlene Campbell
Contributor
Level 1:
Answers
Questions
Helped
664
Points
I tried to find someway to get my machine to work on Windows 7 with no luck. I finally found a rebuilt Windows XP and figure as long as I don't connect to the internet, I should be ok as then it has no way of getting a virus.
Bill Boyd
Level 3:
Top Expert:
  • Janome Master 53,816 Answers
  • Posted on Oct 13, 2015
Bill Boyd
Janome Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948565
Points
172802
Go google and type in-- driver for janome 1000 plus version 3 for win 7 os
the first site up is software updates for janome global site
there are other pages all related to what you are asking for
How to transfer designs from pc to janome memory craft 10000
check with janome to see if they have a update or patch
1helpful
I have memory craft 950.computer crashed and had to relace- now have windows 7 and can not install my cstomiser 10000 plus (ver1.0
There are software updates for the Customizer 10000. See: http://content.janome.com/index.cfm/LearningCenter/Software_Updates . Drivers and installers have changed over time.
I do not know the limitations of the update software.
I hope this helps.
(The other thing to try is the compatibility mode. This may work directly - right click on the installer and choose Properties. Then choose the compatibility tab and set the Program to always run as compatible with XP. Then right click again and choose Run as Administrator. If this doesn't work, another option is to run a second computer with an older version of Windows. You can use a true second computer, a dual boot computer or a virtual computer (which takes a portion of memory from the main computer but doesn't require a restart). If you have Windows 7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. The other options require a valid Windows license for the older OS. Install your Customizer in the older OS as you would normally install the software.)
2answers
Connecting my Memorycraft 10000 to a PC
Have you got the cable that is compatible with your machine. If you are running Customiser 10,000 on your computer it should be fine otherwise it could be that you are running Windows7 not sure about that though.
Why "Digitizer 10000", which used to work on my computer with WinXP SP2, is not working on Windows 7? After installing the software, I click on the button to start the program, but the mistake comes. Help...
Windows 7 is not compatible to your Digitizer 10000.
You may need a software driver to configure it with
the new operating system. You should know that there are lots of things that work with Windows XP and won't work with Win 7. So try surfing the internet
at Microsoft to address your problem.
I can't get the correct driver for Janome MC 10001 for Vista 64bi
See if you can run the program in compatibility mode, with win 2000 or xp.
2answers
JSMC850 DRIVER
I had the same problem. I download the latest version of easy transfer. The driver is in this version. My computer still could not find the driver. I went into the program file where easy transfer was downloaded and copied the driver file for Windows XP or whatever version you use, to a cd. Opened up my device manager found the usb controller with a yellow question mark, double clicked the yellow question mark and clicked reinstall driver. Then you choose the custom install and tell it to look on your cd. It should install the driver. I restarted my computer. Your files should transfer.
2answers
Attempting to find Janome customizer 10000 plus software
Simply contact your nearest Janome dealer, or the Head office in your country and they will be pleased to assist and outline the options available.
MC 10000 Digitizer 10000 Error Message
Try downloading the updates for your software from Janome Global, downloads, software. Version 1 needs patches to make it compatible with XP. The most current Version for the 10000 software is 2.21, and the upgraded program is Digitiser pro/MB , a much more stable and far easier version to work with. The upgrade has to be purchased via a dealer or direct from Janome.
2helpful
4answers
Cannot get Janome 10001 to read via USB direct link from computer
You need to have Customizer og Digitizer pro to send design by cable to you MC10001.
You can also use a PCMCIA adapter in your MC10001 and a CF memorycard..you also need a memorycard reader to write to your CF card from your computer
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
