Anonymous Posted on Jul 13, 2009
Kodak esp-3 unable to scan from home center,but able to print
I have a kodak esp-3. printer working fine on stand alone moda but when ry 2 scan from home center ,it wont do anything, but im able to print from home center tried re installing home center but still scan is not working. help me out
  • Anonymous Jul 28, 2009
    make sure that printer and computer are connected through usb 2.0
    put paper on scanner glass of printer and then try to scan it will ask u to save that document on ur desktop.save it to desired location.
  • Anonymous Sep 21, 2009
    No,i do he have another printer. i have deleted twain_32 folder also, deleted printer from registry and from add or remove programs and then ran clear utility. then i downloaded latest softwares. it did not resolved the issue.
Anonymous
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Contributor 41 Answers
  • Posted on Aug 06, 2009
Anonymous
Contributor
Level 1:
Mentor:
Answers
41
Questions
0
Helped
71242
Points
65
If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
Hopefully that will solve your Home Center scanning issue.
Am I correct in thinking Kodak ESP 3 AIO is not compatible with Windows 7 XP x64? I can print and copy but cannot scan either directly from the button on the printer button or via Kodak Home Center
Hi There,
If you've installed the software at the link below already...
http://support.en.kodak.com/app/answers/list/p/5/session/L3RpbWUvMTMwMTM1NjI3NC9zaWQveldEWnY1cWs%3D%2Fselected%2Ftrue/selected/true#s=eyJzZiI6eyIxMDEyMjIiOnsiZmlsdGVycyI6eyJub190cnVuY2F0ZSI6MCwicGFnZSI6MSwic2VhcmNoVHlwZSI6eyJmaWx0ZXJzIjp7ImRhdGEiOjUsInJuU2VhcmNoVHlwZSI6InNlYXJjaFR5cGUifX0sImtleXdvcmQiOnsiZmlsdGVycyI6eyJkYXRhIjoiIiwicm5TZWFyY2hUeXBlIjoia2V5d29yZCJ9fSwicCI6eyJmaWx0ZXJzIjp7ImRhdGEiOnsiMCI6WzUsNjIsNDMyXSwicmVjb25zdHJ1Y3REYXRhIjpbeyJsZXZlbCI6MSwibGFiZWwiOiJQcmludGVycyIsImhpZXJMaXN0IjoiNSJ9LHsibGV2ZWwiOjIsImxhYmVsIjoiQWxsLWluLU9uZSBQcmludGVycyIsImhpZXJMaXN0IjoiNSw2MiJ9LHsibGV2ZWwiOjMsImxhYmVsIjoiRVNQIDMiLCJoaWVyTGlzdCI6IjUsNjIsNDMyIn1dfSwicm5TZWFyY2hUeXBlIjoibWVudWZpbHRlciJ9fSwiYyI6eyJmaWx0ZXJzIjp7ImRhdGEiOnsiMCI6Wzg5MCw4OTFdLCJyZWNvbnN0cnVjdERhdGEiOlt7ImxldmVsIjoxLCJsYWJlbCI6IkRvd25sb2FkcyBhbmQgRHJpdmVycyIsImhpZXJMaXN0IjoiODkwIn0seyJsZXZlbCI6MiwibGFiZWwiOiJXaW5kb3dzIDciLCJoaWVyTGlzdCI6Ijg5MCw4OTEifV19LCJyblNlYXJjaFR5cGUiOiJtZW51ZmlsdGVyIn19fX19LCJjIjo1fQ..
then the answer would be yes. If you haven't install the software and see how things go.
Regards,
Selk
2helpful
2answers
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
My scanner icon for my ESP 3 has disappeared. My
Kindly download trhe latest Kodak all in one home center software from www.kodak.com/go/aiodownloads .the scanning and printing drivers are embedded in the software itself.
When opening the kodak home center got an error.
it is a scanning error............ scanning usually take 1-2 minutes to scana document. make sure dat u've proper ink in ur cartridges. contact kodak@ 1800 21 6699 for further issues.
Scanner will not work have just purchased the printer and have now got the print working but cannot get scanner working ?
scanning anything will ask for a place to save the document install kodak home center from cd or from net- www.kodak.com/go/downloads connect ur printer and computer with usb 2.0 open home center on computer
and try to scan a document by placing on scanner glass on the printer will be able to scan if not, call kodak 1800 419 1909 for further directions
5helpful
My kodak esp-3 printer is printing with a pink tint to all my pictures. can you help?
open printer access door.remove printhead and cartridges again reseat both of them.. press copy $ cancel for 5 seconds and wait for caliberation sheet to print.. or if u have connected ur desktop, open kodak home center, go 2 maintenance and click on clean printhead. now see if ur documents are printing properly. if not kodak will replace ur printhead.
2answers
Can oper Kodak home center but cant scan or print from it
No you can't print. You need printer icon to operate.
You can try follow steps.
go to device manager ,   expand Universal Serial Bus (USB),  right click on USB Composite Device, Uninstall it. Reboot your computer. You will get a printer icon,
and you can start printing without AIO Home center.
MS
Kodak esp 7 doesnt scan or print properly HELP
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals. KEEP ME POSTED.
Kodak printeresp5 crashes and am not able to get back printing
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.. keep me posted.
3answers
Kodak AiO home center software
I persisted in finding a solution with the help of Kodak but the solution was that the scanner was flawed and the printer is being replaced - AGAIN.  The first tech I talked with was clueless and absolutely no help.  The second person went through some steps with me and determined, once again, there is a flaw in the printer -- the 3rd replacement.  The first printer had a print-head problem out of the box, so it was returned to the store & exchanged for another.  The replacement worked for some 3 months without a hitch and then stopped working - just would not print, but the scanner worked.  So I just rec'd my Kodak ESP-3 number 3 on Tuesday this week.  Printer worked, scanner didn't.  Now I am waiting for my 4th replacement.  It is ridiculous, but when it does work, it is a nice little printer -- quality of photo printing is great, and you can't beat the cost of the ink refills. And so it goes.
k24674
ADMIN Andrew
ADMIN Andrew
