Jerry Coleman Posted on Oct 12, 2015
Canon imageCLASS D530 shows offline - Canon Office Equipment & Supplies
2 Related Answers
Anonymous
  • 460 Answers
  • Posted on Aug 20, 2009
SOURCE: I have a Canon ImageClass MF4150and Vista O/S x64.
pls refix the printer catridge. after refixing it printer is not working then some hardware issue in this printer.
Anonymous
  • Posted on Mar 09, 2010
SOURCE: Canon imageclass mf4122 showing errow E225
2answers
Imageclass d530 error code e100 0001
Hi, tahta erro indicates a malfunction in the laser unit, probably dirty or defective
I did some copying with my Canon ImageCLASS MF4450 and now it won't print from the computer??
go to printer folder from control panel
double click to imageclass see there is some printin quque
delete all print jobs
also right click to printer see there printer is offline make it online then try to print
My compter file says that my Cannon imageclass 2300 is offline what is the prolem?
Go to the CONTROL PANEL on the computer, select PRINTER?FAX icon, then click on the name of the printer you want to associate with your printing needs and make sure it is connected. This will allow the print jobs to go..... Please let me know if there is any thing else you might need, of if it is still offline, we can go further! Guy :) Pleasure to help out.....
2answers
Printer offline
Canon, Brother, and Epson's Printer solutions are mostly the same check this answer.
The Brother Printer offline Windows 10 error normally shows up because of various mechanical issues. There can be difficulties with attachment, print queue, or something else. The printer may be facing some other error. Commonly, the Brother printer will stop printing when Brother printer offline error occurs.
10 steps that Fix Brother Printer Offline Windows 10:-
1. Make Sure The Printer Is Properly Connected.
2. Verify Printer Is Not In Sleep.
3. Check Brother Printer For Any General Errors On Computer.
4. Check Printer Status Offline Or Paused.
5. Check For Copy Of Printer In Devices And Printers.
6.Long Print Queues On Computer.
7. Make The Brother Printer Default.
8. Check SNMP Status.
9. Update Brother Printer Drivers.
10. Update Windows 10 OS.
FULL SOLUTION- Brother Printer Offline Windows 10
If you are not a Technical guy you can take help with us. by just call in Toll-Free Number that is given on Mentioned Blog.
24helpful
2answers
I am using a Canon Image class MF6500 and first I cannot find the driver in the list of downloadable drivers presented and secondly when I go to print a document I get your printer is offline.
to remove the printer from offline right click on it and choose online. and use this link for driver http://canon.driversdown.com/Canon-driver-list/s_119_1.shtml
The printer will not print. it shows that it is offline. i went to the "services" menu and restarted the printer spooler and the printer went to ready but it wouldn't print and then went back to offline....
First thing to do here is to unplug the printer from the computer and restart the computer , then once the computer is already back that's the time you connect the printer back and lets see if the printer will be detected by the computer, if still not and printer is still showing offline, better go to control panel and gp to printers and faxes and click on add and follow the wizard to install a ewn printer that should correct the problem.....
1helpful
2answers
Canon MF5550 offline
go into control panal under printers right click your printer click online
old marine
old marine
ZJ Limited
ZJ Limited
