Question about Jabra Extreme2 Bluetooth Headset
HOW DO I SWITCH BACK TO CALLER ID MODE ON MY JABRA EXTREME BLUETTOTH ?
What does a stand for on the vtech answering machine
It means your system is set to "Announce" mode instead of "Answer." In this mode it announces you're not available to take the call but does not allow the caller to leave a message. If you want the system to take a message, switch to "Answer" mode.
Enter the model of your VTech 5.8GHz system into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
May 21, 2014 | Vtech 5.8 Ghz Handset Cordless Phone...
How do I connect caller ID
First, I'd need to know what switch you have your phone connected to and if the version supports Caller ID. Also, your telephone service must provide Caller ID to your switch (phone cabinet).
Jun 07, 2012 | Toshiba DKT3020SD Corded Phone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Cannot get off demo mode. Sharper Image caller id globe
hold down the 'right' key for a few seconds. this turns it off and on
Feb 02, 2010 | Olympia Info Globe Caller ID Phone
I just got this bt8010 have no idea how it works
You have to install the Jabra Control Center, and it will take you through the steps.
Sep 26, 2009 | Jabra BT8010 Wireless Headset
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
On my model 8885 uniden phone, when I try to store a # the screen say's memory full. I only have two numbers stored. help
These phones use a "Shared" memory, the CID information and the Phone book information share the same memory chip. If you clean out the caller ID data you should be able to load more numbers in the phone book. Since you have an 8885 I am assuming you have TCX800 or TCX905 handset(s), to clear the CID memory, Follow these steps:
Deleting Information from the Caller ID List
1) When the phone is in standby mode, view the Caller ID
information to be deleted (see "Viewing the Caller ID
List" on page 50).
2) Press the DELETE soft key. De let e C all er ID appears.
3) Press volume up/down to choose Yes.
4) Press the OK soft key. You will hear a confirmation tone.
To delete all the CID information follow these steps:
Deleting all Caller ID names/numbers
1) When the phone is in standby mode, press cid.
Press the DELETE soft key. De let e A ll? appears.
2) Press volume up/down to choose Y es.
3) Press the OK soft key. You will hear a confirmation tone
Mar 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
Earhook for Jabra BT350 Bluetooth
try using a large elastic band to "pin" the headset to your ear
Mar 08, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra Extreme2 Bluetooth Headset Logo
76 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
