HKC P774A 7" 8 GB Wi-Fi Black Tablet Android 4.1, LCD Touchscreen, 800x480 Logo
A
Anonymous Posted on Oct 10, 2015
Suddenly wi fi will not turn on
I have even reset to factory settings, says wifi turning on, then just goes to, turn on wifi for available networks
afaq2000ccc
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 54 Answers
  • Posted on Dec 05, 2015
afaq2000ccc
Expert
Level 2:
New Friend:
Greenhorn:
Answers
54
Questions
0
Helped
9274
Points
167
Why does my verizon tablet keep disconnecting from wifi and not accepting my pasword to get back on
There could be several reasons why your Verizon tablet keeps disconnecting from Wi-Fi and not accepting your password to reconnect. Here are some possible solutions:
  1. Restart your tablet and your Wi-Fi router: Sometimes, simply restarting your tablet and router can help resolve connectivity issues.
  2. Check your Wi-Fi signal strength: Weak Wi-Fi signal strength can cause frequent disconnections. Move closer to the router or try to improve the signal strength by repositioning the router or using a Wi-Fi signal booster.
  3. Check your Wi-Fi network settings: Check if your Wi-Fi network settings match those of your router. Make sure you have the correct security settings and password. Try to forget the network and then reconnect and re-enter your password.
  4. Clear your tablet's cache: Clearing your tablet's cache can sometimes help with connectivity issues. You can do this by going to Settings > Storage > Cached data > Clear cached data.
  5. Check for software updates: Make sure that your tablet is running the latest software updates. Check for updates in Settings > System updates.
  6. Factory reset: As a last resort, you can try doing a factory reset on your tablet. This will erase all data on the tablet, so make sure to back up any important files before doing this. Go to Settings > Backup & reset > Factory data reset.
If none of these solutions work, you may want to contact Verizon customer support for further assistance.
I have galaxy note5 softwinerkf026. how I turn on the wifi?
  1. Swipe down the Status bar.
  2. Tap and hold Wi-Fi.
  3. If Wi-Fi is already ON, skip this step.Otherwise, tap the switch to turn Wi-Fi ON.
  4. The device will automatically search for available networks.
    To connect, tap the preferred network.
    Note: If the preferred network is hidden or not available, tap MORE, then tap Add network to manually enter the settings.
  5. If prompted, enter the network Password and tap CONNECT.
  6. The device is now connected to the Wi-Fi network.
I have got acer iconia one 7 and just turned it on. When i go to connect to wifi by sliding it across at top, nothing happens just says'to see available networks turn wifi on?! its not finding any...
You have to turn on the wi-fi connection on the tablet.
Go to settings and turn on wi-fi.
Then go and look at the connections displayed.
Pick which one you want to log on to and enter the appropriate password.
Then you use the internet.
1helpful
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
What are wifi networks when setting up tablets
The wi fi networks are whatever is available in your home or public wi fi network. If it is a free wifi network then simply select it from your tablet and it should connect you up. If it is a secured network then it will prompt for the code that has been set up.
Check the manual on page 28.
http://downloadcenter.samsung.com/content/UM/201401/20140109103000843/SM-T210_UM_EU_Jellybean_Eng_Rev.1.1_130523.pdf
MID 7065 wont connect
try to update firmware or install custome firmware
2helpful
Will not connect to wifi
  • Touch the Apps Menu button on the Home screen.
  • Open the Settings app.
  • Choose Wireless & Networks.
  • Choose Wi-Fi Settings.
  • Ensure that Wi-Fi is on.
    When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
  • Choose a wireless network from the list.
    Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location.
    Optionally, type the network password.
    Touch the Password text box to see the onscreen keyboard.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
    Touch the Connect button.
    You should be immediately connected to the network. If not, try the password again.
  • 1helpful
    2answers
    Can't connect mini iPad to my wifi my other iPad is connected
    Always a good idea to shut down and then turn back on (hold down both home button and power button until it turns all the way off. Wait a couple seconds, then press the power button to turn back on)
    Try wireless again.
    If nothing, then
    Obviously check and make sure wifi is on under settings.
    If still nothing,
    Try resetting your network connections:
    Settings > General, then tap Reset > Reset Network Settings
    If you can't see any wifi networks at all, you might have a bad wifi card in the iPad. Bring back to an apple store.
    Hi i have just bpught an android touchpad but cannot get it to open on wi fi networks
    You need to add the wireless network in which you want to access. You can do this by following these steps on the tablet:
    Press "Settings" button (looks like a filing cabinet on most devices -> then select "Settings" - > then "Wireless and Network" - > then "Wi-Fi Settings" -> then mark the box next to "Wi-Fi" (this will turn on the WiFi antenna -> you will then see the available wireless networks.
    Top HKC Tablets & eReaders Experts
    k24674
    ADMIN Andrew
    ADMIN Andrew
    Are you a HKC Tablet and eReader Expert? Answer questions, earn points and help others
