Scanner wont scan any sheet; the tray lifts and the paper starts to enter the rollers, but then stops and lowers the tray and paper. Then the error pops on the display. The paper is not skewed at all, so i think i need to clean a sensor but where is it? Thanks, Josh
SOURCE: No paper detected
Try cleaning the rollers if that doesn't work, remove all of the rollers (feed seperator and retard) then simply reinstall them. This fixed the errors we had.
SOURCE: dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
S. Mohan, Chennai, India
SOURCE: Scanner pulls page in to just past the bottom sensor lever
Please ensure that the rollers are clean and within its life span. (Rollers wear out and need to changed after 250,000 pages or as recommended by mfr). FAn the pages before scanning, Ensure the edge is trim with no folds or bends. The griniding noise is because the scanner has picked up more than one page.
S. Mohan. India
SOURCE: canon dr-7580 scanner how to initialize cis
Hi, You may need to calibrate a new CIS with new Assembly. Later on this new assembly can be removed and your old one will do. Assembly means solonoid+ shading sheet. This will work for sure Samir Dhingra 9820800633
SOURCE: canon DR-3080c scanner, tray wont lift and says
A scanner will jam for any number of reasons: It's dirty, the wrong
paper type is being used, or the rollers on the scanner that feed the
paper through its pathway are worn down. While cleaning the printer
periodically and using the correct paper type are easy fixes, but thuis are not the the problem, it means the roller is worn out and will need to be replaced.
Take care.
